| Weight of cured paint #194964 10/30/09 07:23 AM 10/30/09 07:23 AM |
Posts: 1,203 uk | Been painting the F32 hull with 2 part epoxy paint [Awlgrip]
The tins of paint seem very heavy compared to domestic oil based paints. You start to add it all up in your head and there seems to be a fair weight of paint on the boat.
As far as high build and ordinary primer goes, I seem to have sanded off most of what I have sprayed on. But the three coats of top coat are a different story....
When it cures, it flashes off the reducer used in spraying, but does any of the actual component in the paint evaporate? For every KG of paint from the tin - does the boat get 1 KG heavier?
Going down the shed to wet and dry some more weight off now, its starting to look sexy by the way!
| | | Re: Weight of cured paint
[Re: TEAMVMG]
#194989 10/30/09 10:44 AM 10/30/09 10:44 AM |
Posts: 4,451 West coast of Norway | Been painting the F32 hull with 2 part epoxy paint [Awlgrip] Awesome! That is a project I am considering plotting in on the long term masterplan. Do you run a blog or a website about your project? | | | Re: Weight of cured paint
[Re: Rolf_Nilsen]
#195018 10/30/09 03:13 PM 10/30/09 03:13 PM |
Posts: 1,203 uk | Been painting the F32 hull with 2 part epoxy paint [Awlgrip] Awesome! That is a project I am considering plotting in on the long term masterplan. Do you run a blog or a website about your project? No - too busy building a boat! I take pictures to keep a sort of log of progress
[Re: Cheshirecatman]
#195019 10/30/09 03:15 PM 10/30/09 03:15 PM |
Posts: 1,203 uk | If so why not take a sample (say 10/20gram) when mixed and see what it weighs when cured. Just remember to take the tare weight of the container beforehand.
Cheshirecatman Do you know how much this bloody stuff costs? I cry every time I waste a drop!
[Re: TEAMVMG]
#195022 10/30/09 03:33 PM 10/30/09 03:33 PM |
Posts: 266 UK |
I two-packed the 5.9 with polygloss last month. Picked up the wrong hardener when doing the second hull - what a mess. At about £50/lt I know what it's like! Cheshirecatman | | | Re: Weight of cured paint
[Re: TEAMVMG]
#195181 11/02/09 07:26 PM 11/02/09 07:26 PM |
Posts: 1,203 uk | Saying that Rolf, i have just thrown together a website; http://teamvmg.weebly.com/index.htmlDon't judge me too much based on that effort!
220
guests, and 29
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
