I do wonder how you are going to keep all panels perfectly trimmed, its hard enough to trim one sail let alone seven! Or would there be some sort of mechanism or computer that does the trimming for all panels? One motor for each panel? At the wing's base there is a spaghetti central which has lines leading to somewhere else:
Re: "My God! It's Full of Wing!"
[Re: Tony_F18]
#195761 11/10/0909:40 AM11/10/0909:40 AM
I like the name coined by our own Jake Kohl. The "Deathspar" is perfect.
I second that, very well thought up.
I already like this Ac for the naming. Like DOGzilla, Cheesezilla, Deathspar, etc
Brilliant.
This AC is so much more radical in all aspects then the previous versions.
To be honest, I didn't coin that phrase - it was someone over at Sailing Anarchy...but it's certainly my favorite over "little wing" (Jimmy Hendrix reference) or "Wingzilla". Rumor has it that Larry Ellison wanted to name BOR-90 the Death Star at some point...but that's a rumor.
#195778 11/10/0911:08 AM11/10/0911:08 AM
there was an experimental human propelled airplane that had one solid overhead wing that was longer tip to tip...but clearly that was an entirely different category. It's considerably longer than one wing off the Spruce Goose or the modern Airbus 380.
#195780 11/10/0911:27 AM11/10/0911:27 AM
still down but the wing is connected to the step and the gin-pole. They've tendered the boat out into the open water presumably so they can hoist the wing and keep the boat oriented into the wind.
