| Small Multihull PHRF #201685 01/31/10 11:33 PM 01/31/10 11:33 PM |
Posts: 337 Arizona | How do I rate my N6.0 orig. W/spi on PHRF? I have scoured the internet and can't find anything. It seems that different areas of the country have formulated their own ratings for larger multi's acording to local racing, but i cant find anything on beachcats.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Small Multihull PHRF
[Re: AzCat]
#201686 02/01/10 12:56 AM 02/01/10 12:56 AM | DougSnell
| DougSnell
Unregistered | | | | Re: Small Multihull PHRF
[Re: catandahalf]
#202935 02/12/10 01:07 AM 02/12/10 01:07 AM |
Posts: 364 | Please further note that the D-PN for the N 6.O original is 64.2, as found on the "Multihulls, Inactive" table.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Will_R]
#203912 02/19/10 10:47 AM 02/19/10 10:47 AM |
Posts: 778 Houston | It's been a long since I did this but I had the same problem. The US Sailing conversion is not applicable to multi's. If you try to sail with that rating and win, you will be protested and thrown out. There may be something about this in the Old Forum I ended up using a method developed by the Corsair's. In simple terms it's hard to convert directly from PHRF to Portmouth because they work diffrently, PHRF is handicap based on distance sailed and Portmouth is handicap based on time sailed. However PHRF has PHRF(TOT) which works just like portmouth so there should be a simple relationship between them. (see http://www.nemasail.org/lussier.html). For data we used a boat with an accepted Portsmouth and PHRF, the F27 with a PHRF of 60 and a porstmouth of .72. I stiil have the spreadsheet which gives INPUT-> 60 PHRF(TOD) calculated 1.07 PHRF (TOT) calculated 0.94 1/PHRF (TOT) OUTPUT-> 0.719999646 Test Calculate Portsmouth# should be .72 INPUT-> 0.626 Portmouth # OUTPUT-> -19.64 PHRF I will look around and see if I can find the details. | | | Re: Small Multihull PHRF
[Re: catandahalf]
#203913 02/19/10 11:08 AM 02/19/10 11:08 AM |
Posts: 3,116 Annapolis, MD | Will there be a white paper comparing the PHRF like rating system comparing to the regional measurement based rating systems?
crac.sailregattas.com
[Re: catandahalf]
#204048 02/21/10 08:45 PM 02/21/10 08:45 PM |
Yep, Im not really looking for Portsmouth, I’m looking for PHRF. It seems that the consensus is that there is no good conversion, and thus no PHRF for beachcats. US Multihulls was trying to get their site running before the AC and hopefully will be able to put out PHRF tables. But it hasn’t happened yet.
[Re: catandahalf]
#204052 02/21/10 10:58 PM 02/21/10 10:58 PM |
Posts: 3,116 Annapolis, MD | Your table assumes that performance is linear in the range of B2-3 and I think that is a problem.
Your deltas seem reasonable for B3 (7- 10 knots or 7.5 to 12 mph) but way off for B2 (beach cat's to mono's.)
The modern high performance cats should be able to fly a hull at 8 or 9 knots (B3) upwind and down wind and sail to those ratings. However, at B2 the beach cats are stuck in the water and I doubt they can sail to the ratings you list and so one rating number for this range is off (one way or the other).
I suspect the B2-3 band was useful when the majority of boats were Hobie 16’s, 18’s etc and indeed their performance was much more linear in this range.
Did you consider wind ratings bands of 0-2... 3-4 and 5 to go home?
[Re: AzCat]
#276532 12/03/14 11:19 PM 12/03/14 11:19 PM |
Posts: 337 Arizona | Resurrecting an old thread! Has there been any more headway with respect to small multihull PHRF?
A bunch of us are sailing in the Governors Cup Regatta this weekend with the local YC and I made the mistake of reading the NOR. There will be a staggered start based on PHRF. The good thing is that the wind will build later in the day, giving the multis a great advantage, if we can provide some numbers.
[Re: mikekrantz]
#276535 12/04/14 09:29 AM 12/04/14 09:29 AM |
Posts: 337 Arizona | I'll check it out, Thanks for the info
[Re: catandahalf]
#276547 12/04/14 01:24 PM 12/04/14 01:24 PM |
Posts: 5,590 Naples, FL | am I to understand PHRF correctly in that it varies by "region" and there appear to be different "scratch boats" in different PHRF areas?
I looked up my C24 rating (from 74 to 90) and it varies depending on which PHRF zone I'm using.
To be anywhere close to bridging the mono/multi conversion gap, would you have to practically sail all boats a nautical mile up and down in various wind/sea states (to get baseline information for future formula development)?
And how the heck would you develop formula(s) for semi- and full- foiling boats?
[Re: jkkartz1]
#276613 12/08/14 02:29 PM 12/08/14 02:29 PM |
Posts: 5,590 Naples, FL | I think I hit the web page for a form, but not sure...?
[Re: jkkartz1]
#276623 12/09/14 09:39 AM 12/09/14 09:39 AM |
Posts: 5,590 Naples, FL | Not that one. Thanks for the linkey.
Since I don't know, and am too lazy to measure myself, can I submit just as a "stock" boat (no modifications) and would they know enough about multihulls to be able to crank that out for me?
452
guests, and 46
