F16 Effect Crew Weight Solo and 2 Up
by samc99us. 07/20/18 01:12 PM
CL258 and CL259 Clamcleats for Trap Harness
by samc99us. 07/20/18 01:11 PM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
Reccomended Main Sheet and Block set for racing #201467
01/27/10 10:52 PM
01/27/10 10:52 PM
Saint Thomas Cat Offline OP
Hi,
I am looking for the best bang for the buck for a new mainsheet as well as a block set. Any ideas? I did search and couldn't find any tips.
Thanks
Re: Reccomended Main Sheet and Block set for racing [Re: Saint Thomas Cat] #201468
01/27/10 11:08 PM
01/27/10 11:08 PM
Seabrook, TX
DougSnell Offline
DougSnell  Offline
Seabrook, TX
Start here depending on the purchase you need:
https://store.catsailor.com/pc/viewCategories.asp?idCategory=331
Doug
Re: Reccomended Main Sheet and Block set for racing [Re: DougSnell] #201488
01/28/10 08:27 AM
01/28/10 08:27 AM
Virginia Beach
Sunvista Offline
Sunvista  Offline
Virginia Beach
The stock system is 5:1. Most here will tell you anything higher than 6:1 is overkill for the H-16.
Re: Reccomended Main Sheet and Block set for racing [Re: Sunvista] #201502
01/28/10 11:33 AM
01/28/10 11:33 AM
California
mmiller Offline
mmiller  Offline
California
Correction... 5:1 use to be stock a LONG time ago. 6:1 low profile has been the go since the early 80's.
Current stock setup is Harken triple lower with ratchet H194 and triple upper H2640 with 40 feet of 3/8 line.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Reccomended Main Sheet and Block set for racing [Re: mmiller] #201512
01/28/10 12:40 PM
01/28/10 12:40 PM
Thanks guys.
I bought some of the old school 6:1 blacks that are probably not where near "low profile" enough because I am almost always block to block going up wind.
My crew weight is LOW since it's me and my kid who range from 50-100 pounds. I'm about 155
I rake the mast to mitigate the pitch pole action although it's the highlight of the day for my crew:)
I see the block set that is reccommended on the Hobie brochure.
Which is the stock set?
https://store.catsailor.com/pc/viewPrd.asp?idproduct=8221&idcategory=331
or below.
https://store.catsailor.com/pc/viewPrd.asp?idproduct=8223&idcategory=331
I like the auto ratchet idea. Is it class legal?
Are the only class legal sails from Hobie?
Thanks for the great forum and to all who post on it!
Re: Reccomended Main Sheet and Block set for racing [Re: Saint Thomas Cat] #201539
01/28/10 04:43 PM
01/28/10 04:43 PM
California
mmiller Offline
mmiller  Offline
California
Neither link shows the stock set. Both will work fine. I prefer to control when the ratchet is engaged... don't like the auto ratchet feature. One set shows the stock lower H194 and the other the stock upper H2640.
H16 Class Legal sails are Hobie factory made only.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Reccomended Main Sheet and Block set for racing [Re: mmiller] #201547
01/28/10 05:47 PM
01/28/10 05:47 PM
Virginia Beach
Sunvista Offline
Sunvista  Offline
Virginia Beach
There are dozens of boats around here from the early 80's. In our little "yacht club" we have a '79, two '82's and an '84. Before we upgraded the early boats all had two hangers on the boom with single blocks. The '84 had a double upper but was still 5:1.
Which brings up another question....how far back on the boom is the block hanger on the newer boats? Not sure which of my two block hangers I should be using for a triple upper. Due to the takeoff angle, one works better from the tramp and the other better from the trapeze. Maybe I should put another hanger right in between.
Re: Reccomended Main Sheet and Block set for racing [Re: Sunvista] #201551
01/28/10 07:30 PM
01/28/10 07:30 PM
California
mmiller Offline
mmiller  Offline
California
Looks like 1986 was a factory drawing change to a single boom bale at what looks like 81.5 inches aft of the forward end of the extrusion. They also tilted that bale forward 13 degrees in 1988. We have since revised this dimension further, but I can't place a drawing at the moment. To use the current / latest dimension, you should use the latest step casting and base though. They allow max rake and that started with the 2004 Worlds boats.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Reccomended Main Sheet and Block set for racing [Re: mmiller] #201657
01/30/10 10:03 PM
01/30/10 10:03 PM
I rescued this boat from the bush. Little other than the hulls are the original from new.
My boom has two bails on it and I'm thinking that this could be part of my block to block issue. Even with the mast as forward as possible it bottoms out occasionally.
I am going to try to move the shrouds down to the bottom hole and see if after tensing the jib halyard all the way I can get decent tension on the sails when I need.
Thanks
Re: Reccomended Main Sheet and Block set for racing [Re: Saint Thomas Cat] #201878
02/02/10 03:25 PM
02/02/10 03:25 PM
Virginia USA
CMerrell Offline
CMerrell  Offline
Virginia USA
On two bale (i.e. pre 6:1) booms, I've heard it is better to hang 6:1 blocks from the forward bale as it causes less stress on the gooseneck. In very light air, blocks on the rear bale may provide a little better response.
Having said that, I have never heard of a H16 gooseneck breaking. H17 on the other hand ...
Re: Reccomended Main Sheet and Block set for racing [Re: mmiller] #201883
02/02/10 03:52 PM
02/02/10 03:52 PM
I measured a new one last summer at 82-3/8"
that's good to know
With my "old school" setup, I've always used the rear bail...will try the front in heavier stuff
Re: Reccomended Main Sheet and Block set for racing [Re: _flatlander_] #202214
02/04/10 11:29 PM
02/04/10 11:29 PM
I changed the position on the shrouds. Now I know why I was slower on one tack that the other smile The are both "even" and lower. I can tension the jib halyard nice and tight and have good rake. The blocks don't touch as easily know.
As simple as these things are I still have so much to learn. Looking forward to getting Ricks DVD to pick up some more tips.
Got out in some really heavy stuff the other day. 6-8' swells and 25 + knots of wind. She sailed great! Big fun
Need a new main sheet now. My old one gets very heavy and slips off the boat all the time. PITA
0 registered members (), 19 guests, and 223 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
JeffS 4
Gato 3
Beata 1
Topics22,312
Posts266,607
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
