| Re: Sailing my 1st boat yesterday - n5.5u
#20750 06/12/03 06:41 PM 06/12/03 06:41 PM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | I found the leaks on the from fittings where the bridle (foil) attahces. Makes sense. Everytime you bury a bow at speed. there is pressure that just forces the water in. There was another under the lip inside the daggerboard well. Same thing. Easy fix.
Don
Don Cook
ARC22 #2226
ADRENALIN
[Re: Cookie Monster]
#20751 06/12/03 11:36 PM 06/12/03 11:36 PM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | I found the leaks on the from fittings where the bridle (foil) attahces. Makes sense. Everytime you bury a bow at speed. there is pressure that just forces the water in. There was another under the lip inside the daggerboard well. Same thing. Easy fix.
Don Using a similar method for pressurizing the hull, I found leaks around the rivets that hold the 4-way jib track to the hull. I also pressurize my mast (through the holes that the rotator mounts through) and check for leaks each spring.
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Kevin Rose]
#20752 06/13/03 07:06 AM 06/13/03 07:06 AM |
Posts: 12,310 South Carolina | the first place my mast leaked was that rotator connection.
Jake Kohl | | | Re: Sailing my 1st boat yesterday - n5.5u
#20753 06/15/03 04:59 AM 06/15/03 04:59 AM |
Posts: 43 Austin, TX | Speaking of Mast rotators, the guy (not carl) who sold me the boat said not to worry about it, I would not need to use it until I got more experienced. Is this true? Should it be rigged at all to prevent any type of over-rotation?
Also, I noticed in the newer Nacra owners manual it says to take the mast step pin out after the mast was stepped - is this advisable?
-Brandon N5.5u #424 Austin, TX
-Brandon
N5.5u #424
Austin, TX
[Re: Aggie97]
#20754 06/15/03 10:05 AM 06/15/03 10:05 AM |
Posts: 3,114 BANNED | Yes and Yes  Make sure you don't over-rotate and yes take the pin out. I have firsthand experience of what happens when your mast comes tumbling down and you left the pin in the base. Not pretty. | | | Re: Sailing my 1st boat yesterday - n5.5u
[Re: Aggie97]
#20755 06/15/03 02:19 PM 06/15/03 02:19 PM |
Posts: 364 | The 5.5u like many boomless Nacras uses a forced rotation system. Rotation takes care of itself most of the time; you would force rotation to maximize sail area downwind in a racing situation, and sometimes upwind in very light air. For cruising, I agree...don't mess with it. As for pulling the pin: Do pull it, but carry it on the boat. Some of the most experienced Nacra sailors I know keep it attached to an eyestrap rivetted to the main beam near the mast step.
good luck w/a great boat
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Andrew]
#20756 06/15/03 06:48 PM 06/15/03 06:48 PM |
Posts: 43 Austin, TX | Thanks folks, the pin will come out next time!
-Brandon
N5.5u #424
Austin, TX
270
guests, and 50
