| Re: harken furler
[Re: banannahead]
#20966 06/16/03 12:27 PM 06/16/03 12:27 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Hello, I mounted the Harken Furler in the conventional manner (Harken lettering up) and it worked fine that way. I would see no reason to mount it upside down. My bridle wires attached to the shackle in the photo below. Good luck, Jack
Jack Hoying
Fort Loramie, Ohio
| | | Re: harken furler
[Re: jmhoying]
#20969 06/16/03 06:54 PM 06/16/03 06:54 PM |
Posts: 33 Missouri | Hi, I called Matt at Hobie and he says the harken furler does have the shackle on the top and that the drum is inverted, (harken logo down), but he said I could put another larger shackle on the bottom, since the one that is on top now is too narrow, so the furler is logo up. When I said shaved I meant to say the shaft is ground down a little on two sides so the shackle fits, Matt said the ground down area would not affect anything, but I am not going to grind the other shaft down. I will get a bow shackle that will fit, (instead of a D shackle, which is on it now), so I won't have to grind down the sides of the shaft, that way it will be set up like your's, which makes more sense. So I guess I will have to go to St. Louis to pick up a larger bow shackle and make sure everything fits right, Hopefully I will get to sail sometime this summer!
Thanks for all the help! The photo helped me a lot!
321
guests, and 38
