Page 1 of 3 1 2 3
ratings #209821
04/29/10 12:01 PM
04/29/10 12:01 PM
pgp Offline OP
pgp  Offline OP
I read on the main board some time back that there is only one winner and that is first place; second place is just the first looser.
I disagree. Since I read that post, I've been trying to think of a way to make racing more interesting for those of us who do not finish first, or win any trophy at all. Of the ideas I've considered, I like the idea of rating the sailor best.
What I have in mind is not a handicapping system to win a trophy but a grading system to measure improvement and to quantify that improvement.
Anyone else interested in such a system?
Pete Pollard
Blade 702
Re: ratings [Re: pgp] #209825
04/29/10 12:28 PM
04/29/10 12:28 PM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Pete,
What were you thinking?
We used to have a system in our local fleet where time differences were kept between all the boats and averaged to give a handicap rating. We then had reverse starts based on this at local events.
I suppose you could combine results comparing various fleets around the country by the relative results of the few who travel between different fleets, kind of like the college sports rankings.
All this would take is someone taking and compiling times at every race.
M
Re: ratings [Re: Matt M] #209842
04/29/10 02:41 PM
04/29/10 02:41 PM
pgp Offline OP
pgp  Offline OP
I wasn't thinking anything remotely like that, more like time trials, one boat on the course at a time.
Pete Pollard
Blade 702
Re: ratings [Re: pgp] #209847
04/29/10 03:39 PM
04/29/10 03:39 PM
Unless you can keep the wind strength constant, and from the same direction for the duration of this time trial event, how would it be a 'fair' rating? And what purpose would your rating have once obtained?
I understand Matt's example and I've always liked the way they start the Mug Race, slow boats first, faster boats start last and have to pass everyone to win, but again, if the wind is not -contstant- all day long, and it rarely is, it's really not fair to the boats who start (or finish) in the light wind vs. boats sailing in the better wind.
I did't really like racing PHRF in mono's, where you have to wait around after the finish to see if you "saved your time" over a slower boat, same for Portsmouth racing in cats, but it beats no racing at all I guess.
Re: ratings [Re: Timbo] #209849
04/29/10 03:47 PM
04/29/10 03:47 PM
Live in Germany, House in UK, ...
DanTnz Offline
DanTnz  Offline
I don't know how it does it, but this Kiwi system allows boats the race all over the country to be ranked beside each other. You can measure your increase in performance by climbing the rankings.
http://racetrack.org.nz/index.htm
Re: ratings [Re: DanTnz] #209855
04/29/10 04:35 PM
04/29/10 04:35 PM
pgp Offline OP
pgp  Offline OP
I'm still not making my point very well, so let me try another approach.
Shouldn't you be able to predict mathematically how a boat will perform? If so, you predict an outcome and compare that to an individual's actual performance.
For instanced if our model predicts a boat should attain ten knots on a certain course but a sailor only attains eight his performanc could be expressed as .8 or, .800.
Carry this a little further. Let's assume, arbitrarily, that a tack should take ten seconds, and that a weather leg of 100 meters should be sailed in six minutes. If a sailor is required to make four tacks while sailing the 100 meters, his best possible time would be six minutes forty seconds and score 100%. If in fact he sails the course in ten minutes, his score would be .667 (6.67/10= .667) And that would be his rating- .667.
Obviously we would need to add an adjustment for a start and for a down wind leg.
Pete Pollard
Blade 702
Re: ratings [Re: pgp] #209856
04/29/10 04:40 PM
04/29/10 04:40 PM
OK, but how do you define the -baseline- or the 100%? Is it a relative thing, ie. the 'fastest' guy at the time trials is the baseline 100% model, and then every one else is some percentage over his time on the upwind leg you described?
That works for that day, but then later in the year, how do you figure you are improving? By how close to that guy you finish in another race? What if he got slower instead of you getting faster?
I've been in favor of measurnig our courses so we can tell how fast we are going, upwind and down, and I think that would help in your system, as we would need couses to be exactly the same distance, but what about the wind?
Re: ratings [Re: Timbo] #209857
04/29/10 04:50 PM
04/29/10 04:50 PM
pgp Offline OP
pgp  Offline OP
I THINK a polar could determine the base line.
Pete Pollard
Blade 702
Re: ratings [Re: pgp] #209858
04/29/10 04:56 PM
04/29/10 04:56 PM
Again, we would have to measure our courses, but with today's GPS, it should be pretty easy to get them fairly close to what ever distance we decide is best. (1 mile upwind?)
Re: ratings [Re: pgp] #209880
04/30/10 02:13 AM
04/30/10 02:13 AM
Mark P Offline
Mark P  Offline
Check out Sailwave, there you can have BCE and BCR Columns added to the results. A competitors BCR figure is the rating they actually raced to. For instance if a F16 wins a race they raced to their rating (TEXEL 102). However, the second boat was a F18 and depending how far they were behind the F16 their BCR could be 103 (TEXEL F18 rating is 100), third was another F16 and again depending on the time difference their BCR could be 104. So the BCR gives an automatic "rating" based on the BCE which is the adjusted time they lost by, or to put it another way the amount of time they needed to be quicker to win the race.
Therefore, you could possibly use this information over time to come up with a persons average BCR rating (Their actual performance rating. A F16 using TEXEL is 102 however, my actual rating based on last years results could be 105!).
I guess you could use this information to come up with National rankings like they do in NZ or in our case if all F16 were scored using Sailwave you could theoretically produce a fairly accurate World Rankings list based on "Club Racing Results"
MP*MULTIHULLS
Re: ratings [Re: Timbo] #209884
04/30/10 04:30 AM
04/30/10 04:30 AM
Mark P Offline
Mark P  Offline
A friend of mine has just returned from a National Mark laying course in preparation for the Olympics and has found out that his fairly expensive Marine GPS was positioning himself 300m differently to the Instructor /Examiner on several occasions. When he returned home and phoned Garmin they weren't exactly helpful and thought that 300m was an acceptable degree of inaccuracy. Martin then explained that the competitors at the Olympics may not have the same view. Garmin could only suggest that a more expensive GPS would probably be more accurate.
So I guess you can't believe everything your GPS is telling you as it sounds that they aren't as accurate as Garmin would like to make you think.
MP*MULTIHULLS
Re: ratings [Re: Mark P] #209885
04/30/10 05:01 AM
04/30/10 05:01 AM
DanTnz Offline
DanTnz  Offline
Mark, I'm no expert on this (although I bet some of the ex-pilots on here are), but there are many many variables to GPS, the handset yes, but also which satelites are being picked up and whether there is a variable offset. When I was still serving we were issued mil codes for GPS as the US (who own the system) would insert a variable offset in the system to ensure it could not be used for military purposes. That said, I beleieve the GPS would still be accurate relative to itself, i.e. if you used the same GPS to mark out the whole course, the distance and angles between marks would still be right. This might have changed though as I heard the offsets were reduced or removed. When I did some time on a survey boat, they would set up ground stations at known locations for coastal work so they always had a absolute reference (known as Differential GPS I think).
Apparently the new Euro system we are all being taxed for will be very accurate and not use any offsets.
Any experts out there?
Re: ratings [Re: Mark P] #209886
04/30/10 05:28 AM
04/30/10 05:28 AM
waynemarlow Offline
waynemarlow  Offline
Mark, In GPS terms 300m is unacceptable and Garmin would be facing law suits all over the world if their GPS's were that inaccurate from boat owners running aground and hitting things, at that level of accuracy no one would purchase one.
My guess that there was a possible explanantion or a fault with the unit itself. Classic GPS inaccuracy in hand helds is from the aerial not being in the right position, ie shielded by an object or not being in the right vertical orientation.
The other option is of human error in reading the unit by abbreviating the minutes to only 1 or two digits.
Easy test for the unit though is put it on a fixed object and let it record for about 2 hours, it shouldn't deviate by more than about 10 metres horizontally and about 30 metres vertically. More than that and send it back to be repaired with the trace still in the unit. Its dead obvious when the unit is not doing what it should, the readings dither about all over the place, though the worst I have seen was about 100 metres.
Re: ratings [Re: waynemarlow] #209888
04/30/10 06:34 AM
04/30/10 06:34 AM
Mark P Offline
Mark P  Offline
I take your point Wayne and I'm sorry about the thread hijack. Maybe I could have been a bit more explicit because when Martin explained the problem the person on the other end of the phone at Garmin knew which model GPS unit Martin had before Martin had told them. So Garmin are aware that there is an accuracy problem. However, because this Unit is over three years old they weren't prepared to fix or replace it under warranty.
I guess you just pay your money and take your chance but in Martin's case having known him for a long time he has definitely looked after this and all his other mark laying kit.
MP*MULTIHULLS
Re: ratings [Re: Mark P] #209889
04/30/10 06:43 AM
04/30/10 06:43 AM
SE Qld, Aus.
N
NickoPen Offline
NickoPen  Offline
N
SE Qld, Aus.
There was a recent inquest into a yacht grounding in Sydney during an overnight race where a couple of VERY experienced (like 20+ Sydney to Hobarts) racers died. One of the findings was that in some conditions, even the best GPS (when not using RTK etc) can be several hundred meters off.
On the other hand, velocity measurements by GPS use a doppler type calculation, which is completely different physics to the position calculation. Velocity and heading should be pretty accurate once you get above 1 or 2 m/s.
Re: ratings [Re: Mark P] #209892
04/30/10 07:32 AM
04/30/10 07:32 AM
pgp Offline OP
pgp  Offline OP
This is more like what I had in mind,except that I'd like to see ratings races run on very short courses, perhaps ten minutes total. The point is to make PRACTICE more fun and competitive as well as to be able to measure improvement.
Pete Pollard
Blade 702
Re: ratings [Re: Mark P] #209893
04/30/10 07:33 AM
04/30/10 07:33 AM
waynemarlow Offline
waynemarlow  Offline
Yes we had a period of time where the Garmin units we were supplying suddenly started to become very inaccurate ( not so good for gliding competitions ) and all were the units with an attached aerial rather than the built in aerial type. We replaced the aerials with after market units at about half the cost of the genuine Garmin units with good results.
As I say just sit it on a fence post and then have a look at the trace, if it moves around randomly, then chuck it in the bin and buy another.
Re: ratings [Re: waynemarlow] #209898
04/30/10 08:04 AM
04/30/10 08:04 AM
pgp Offline OP
pgp  Offline OP
You guys are making this way to complicated! Use of a gps in this application is ridiculous. Geometery would be much more useful. Particularly on a windward/leeward course of 100-200 meters.
Pete Pollard
Blade 702
Re: ratings [Re: Timbo] #209899
04/30/10 08:25 AM
04/30/10 08:25 AM
pgp Offline OP
pgp  Offline OP
Pete Pollard
Blade 702
Re: ratings [Re: pgp] #209901
04/30/10 09:56 AM
04/30/10 09:56 AM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
At a 300 m deviation, the GPS is still way more accurate than any course performance you might be able to get. Changes in wind strength, dirrection, waves, currents, salinity, altitude.
Page 1 of 3 1 2 3
1 registered members (vasil), 372 guests, and 39 spiders.
