| Re: Shopping for a boat
[Re: pepin]
#211149 05/15/10 04:09 PM 05/15/10 04:09 PM |
Joined: Apr 2007 Posts: 148 Cutler Bay, Florida Bajan_Bum
Posts: 148 Cutler Bay, Florida | Those boats mostly come with spinnaker these days, or can be equipped with one. You can remove the spi hardware and sail them without it, but frankly that would be a shame. Spi are mounted into a sock and go up in three seconds on any tack. I can manage steering and the spi on my F16 sailing solo, no problem. It just takes a bit of training.
Hey Pepin, awesome info. Are you saying you handle the main, jib and spin alone on the F16? Or just the Main and spin?
[Re: Bajan_Bum]
#211153 05/15/10 07:10 PM 05/15/10 07:10 PM |
Posts: 1,383 Kingston SE South Australia | If the 570 doesn't work out you should try a Nacra 5.8, your budget would get close to a new one, they don't need a spinnaker and are very forgiving when your first getting used to it then if you get serious you can learn how to power it up. The downside is learning how to handle the weight on the beach, the beach wheels need to be under the middle then you can put it on and off the trailer on your own. They've got high buoyancy bows I never pitchpoled mine even when jumping one wave into the middle of the next, no boom and 4 people for cruising is fine. It's got a big jib, if you get serious about pointing up as in racing and your wife is not too strong she would have to hand you the jib sheet for you to pull the last bit on.
[Re: pepin]
#211162 05/15/10 10:22 PM 05/15/10 10:22 PM |
Posts: 757 japan |
[Re: pepin]
#211163 05/15/10 11:35 PM 05/15/10 11:35 PM |
Posts: 148 Cutler Bay, Florida | Hey Pepin, awesome info. Are you saying you handle the main, jib and spin alone on the F16? Or just the Main and spin?
A class compliant F16 is main+spi solo, Main+jib+spi in duo. But I've used my jib solo before, only in low wind however, when it's windy you don't need the jib there is enough power as it is. Not to mention that I only have two hands and that's already not enough Thanks for the reply. | | | Re: Shopping for a boat
[Re: erice]
#211164 05/15/10 11:37 PM 05/15/10 11:37 PM |
Posts: 338 | There is a NACRA 5.8 listed in Vermont listed in the classified section - that seems a bit more closer than the 570 in California. Also check out New England Catamarans I'm sure Rick has his ear to the ground on folks looking to sell their boats. Also the Cat House http://www.cathouse1.com/main.htm | | | Re: Shopping for a boat
[Re: Nimrod]
#211168 05/16/10 03:40 AM 05/16/10 03:40 AM |
Posts: 1,383 Kingston SE South Australia | Take the 5.8 for a run on a reach in 17kts, keep it flat and watch all the fine spray around the back of you while you stay dry as the boat with its wide flat hulls skips like a pebble accross the top of the chop then try the others. Or do the same with 3 people in 20 kts
[Re: old salt]
#211402 05/19/10 08:53 AM 05/19/10 08:53 AM | andrewscott
| andrewscott
Unregistered | Hope your family gets well.
PS don't worry about missing an opportunity, there will always be boats for sale~! | | | Re: Shopping for a boat
[Re: old salt]
#211923 05/26/10 11:39 AM 05/26/10 11:39 AM |
Posts: 1,430 california | Where is your boat coming from? Was it the one from Long Beach? Great boats you will enjoy it.
373
guests, and 95
