Tightening of the Dolphin Striker? #21583
06/28/03 01:17 AM
06/28/03 01:17 AM
Seabrook, Tx
PrindleFish Offline OP
Seabrook, Tx
My older model Prindle's dolphin striker is a little loose as per manual specs. I tried to tighten it up and the stainless steel post is frozen. I used some sprays on it to loosen it but have had no success in getting it to move. Anybody have any suggestions on how to get it loose? Or should i worry about it at all??
PrindleFish }=)))*>
Re: Tightening of the Dolphin Striker? [Re: PrindleFish] #21584
06/29/03 11:40 PM
06/29/03 11:40 PM
catman Offline
catman  Offline
I not sure what your striker looks like or how it adjusts, but nothing loosens stuff like heat. The torch kind. Careful to not burn the tramp, use a propane torch and warm it up a bit. It dosen't have to be red hot, just pretty darn hot. If heat won't do it forget it and replace it. If it's that corroded it might fail causing more expensive damage to you or your boat.
0 registered members (), 264 guests, and 46 spiders.
