Dart 18 specs #216580
07/28/10 10:42 AM
07/28/10 10:42 AM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
Anyone with a Dart 18 know the distance between the center point of the holes for the tiller arm pins on the rudder crossbar? Trying to make a new one.
Thanks
Ryan
Dart 18 #4860
Re: Dart 18 specs [Re: Twister] #216584
07/28/10 11:46 AM
07/28/10 11:46 AM
Re: Dart 18 specs [Re: Twister] #216596
07/28/10 06:53 PM
07/28/10 06:53 PM
Florida, Pnellas, USA
dartfast Offline
dartfast  Offline
Print DR 250 only states "1950 Max" cross barlength of rod and holes to fit DR 237 pins "to fit assembly". Mine measures bar at 72 5/8 inches with hole centers at 69 5/8 inches.
To firm and minor adjust Stu made two 1.75" long wood dowel inserts with through holes for the pins and slides the dowels inside the cross bar ends and uses a screw to make the dowles firm. Reduces play and wear.
Terry
Terry
Re: Dart 18 specs [Re: dartfast] #216602
07/28/10 08:16 PM
07/28/10 08:16 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Hi,
Find Mark Schnieder ..... send him a PM ....
Oh, Mark's origonal sailing nickname .... "Dartman"
And he still has his .....
Harry
Re: Dart 18 specs [Re: scooby_simon] #216622
07/29/10 07:40 AM
07/29/10 07:40 AM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
Thanks
Thats a great idea.
Ryan
Dart 18 #4860
Re: Dart 18 specs [Re: Twister] #216655
07/29/10 11:23 AM
07/29/10 11:23 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Had a wander around the boat park today, there is usually at least one slacker on a Dart 18 that can't be bothered to take his rudders off. But, wouldn't you know it, no rudders to be seen!
no use - sorry!
Re: Dart 18 specs [Re: Twister] #219007
09/08/10 11:34 AM
09/08/10 11:34 AM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
Are the backing plates and hardware for the chainplates and bridle attachment points glassed in place from the inside.
I am wondering since I am planning on refinishing the hulls and would like to remove these fittings unless they will be difficult to replace.
Ryan
Dart 18 #4860
Re: Dart 18 specs [Re: Twister] #219027
09/08/10 02:21 PM
09/08/10 02:21 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
If I remember right, the baking of chainplates on bridle attachment are not glassed. I had serial number 6913.
Cheers,
Klaus
Re: Dart 18 specs [Re: Smiths_Cat] #219028
09/08/10 02:29 PM
09/08/10 02:29 PM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
Is there anything holding the backing plate and hardware in place, like epoxy? There are no inspection port access, so I dont want to have any hardware dislodge when I remove them.
Ryan
Dart 18 #4860
Re: Dart 18 specs [Re: Twister] #219050
09/08/10 06:11 PM
09/08/10 06:11 PM
DO NOT undo any of the fittings unless you are planning to take the decks of the boat off too. They are NOT epoxied in.
Re: Dart 18 specs [Re: scooby_simon] #219081
09/09/10 08:33 AM
09/09/10 08:33 AM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
That's what I thought. Just wanted to confirm. Thanks.
Ryan
Dart 18 #4860
0 registered members (), 221 guests, and 21 spiders.
