| Calling all old QB2 sailors #211888 05/26/10 06:03 AM 05/26/10 06:03 AM |
Posts: 1 | Wanted old (& young) QB2 sailors. We are proposing to have a re-union in December 2010. We would like to get together with as many QB2, QB3 sailors as can manage to get to McCrae in Victoria. If anyone still has a QB2 to show off that would be great. Please respond with interest to [email protected]. St | | | Re: Calling all old QB2 sailors
[Re: pepin]
#211950 05/26/10 03:18 PM 05/26/10 03:18 PM | MarkMT
| MarkMT
Unregistered | From here - ![[Linked Image]](http://i136.photobucket.com/albums/q183/hihosilver1953/Cat_After.jpg) | | | Re: Calling all old QB2 sailors
[Re: ]
#211988 05/26/10 11:30 PM 05/26/10 11:30 PM |
Posts: 586 Hobart, Tasmania, Oz. | The Q stands for Quest, the B is B-Class, but the 2 I have no idea!
catsailor.net is broken, when you make anew post its blank. the owner does not seem interested in fixing it.
[Re: Dazz]
#212004 05/27/10 04:48 AM 05/27/10 04:48 AM |
Joined: Jul 2001 Posts: 953 Western Australia Stewart
Posts: 953 Western Australia | QB2 fitted the B2 class.. This was probably started by Neil Fowler in Darin with his Black Witch class. The class rules were 18x8x225
QB2 was a modified A hull. Cunningham had an old Proctor built Cunningham A class platform. After work Cunningham and Proctor took the deck off the A tweeked the bows and put on new beams. Bruce Proctor still around with lots of info.. He says his recollection B2 because it was like a B class but you couldn't call the class B2/3!! Brian Cronin from Supreme Sails sailmaker. Bruce was the main builder and has all the numbers and names in his files.
The first boat was sailed by Bruce Proctor/Barry Marmion? at the one of a kind regatta Frankston. Dry land tuned and won her first regatta.
I believe the stingray class is a B2.
[Re: Qb2]
#217321 08/09/10 03:16 AM 08/09/10 03:16 AM |
Joined: May 2008 Posts: 107 Melbourne, Australia MitchB
Posts: 107 Melbourne, Australia | I believe the difference between the QB2 and QB3 is the same as the difference between Stingray Mk1 and Stingray Mk2...
Mast upgraded to Wingmast (mostly Superwing.. same section used by F16 today!), and extension by 2-3ft, Increase in sail area from ~200sq/ft to 225sq/ft
I suspect these boats had no minimum rigged weight, just platform weight, the stingray was 88.5kg... I think the QB was lighter!
Stingray #579 GLYCish
505
guests, and 40
