Main Outhaul #217425
08/12/10 02:50 AM
08/12/10 02:50 AM
Kiel, Germany
Baltic Offline OP
Baltic  Offline OP
Kiel, Germany
How do you determine the correct position of the main outhaul? I've heard that there could be a fixed position and it then varies alongside the main downhaul. How do I find this position?
F18: C2 / A-Cat: Minelli
Re: Main Outhaul [Re: Baltic] #217440
08/12/10 09:44 AM
08/12/10 09:44 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
I set mine with the main sheeted tight and the down haul fully on. then I pull the out haul till the sail had about 1/2 inch deflection.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Main Outhaul [Re: F-18 5150] #217499
08/13/10 11:51 AM
08/13/10 11:51 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
what he said
Re: Main Outhaul [Re: F-18 5150] #217515
08/13/10 01:52 PM
08/13/10 01:52 PM
Kiel, Germany
Baltic Offline OP
Baltic  Offline OP
Kiel, Germany
That is what I've been told from others. However, when I sheet in as much as possible, the outhaul can't be moved anymore. So I assume an adjustment and check if I end up with 0,5 inch?
0 registered members (), 433 guests, and 22 spiders.
