Storing boat on water...How long is OK?? #22051
07/10/03 09:31 PM
07/10/03 09:31 PM
Minneapolis, MN
duganderson Offline OP
Minneapolis, MN
I'm going to have my used Hobie 21 Sport Cruiser on a Lake in Minnesota for 1 week. I'd like to leave it on the water on anchor for the week, but I'm wondering if that too much time in the water? How long is OK if the water before damaging the hulls.
Also, do you think it is OK to attach the anchor to the middle of the front crossbar or should I rig two lines off off the forestay connectors at the front of the hulls?
Thanks, Doug
Re: Storing boat on water...How long is OK?? [Re: duganderson] #22052
07/10/03 10:06 PM
07/10/03 10:06 PM
Seabrook, Tx
PrindleFish Offline
PrindleFish  Offline
Seabrook, Tx
Should be no problem. Just as long as you anchor it well. The worst thing that could happen to the hulls is that you might have a little bit of algea growing, but it usually takes a couple of weeks before the green stuff starts to take hold. No way to pull it on land and let it sit in the grass or sand??
PrindleFish }=)))*>
Re: Storing boat on water...How long is OK?? [Re: PrindleFish] #22053
07/10/03 11:16 PM
07/10/03 11:16 PM
Nacra546 Offline
Nacra546  Offline
A week "should be" fine.
I have had my brothers Hobie 16 on a moring for a few days here and there. Tied off at the mast base and with a relatively taught line between the shrouds to take up slack so the waves dont bang the rig around. Tied rudders off, too. My Nacra sits in the drink for a week during the family vacation and it stays dry. If the boat is solid, short term shouldnt be a problem.
Nacra 6.0NA to kill myself quickly and a Johnson 18 to do it a little slower.
Re: Storing boat on water...How long is OK?? [Re: duganderson] #22054
07/10/03 11:23 PM
07/10/03 11:23 PM
catman Offline
catman  Offline
Doug, You'll have no problem anchoring for a week. Just make sure the hulls don't leak. Anchor using enough scope. I use a bridle attached to the bridle tangs. I think the 21SC bridle tangs have a extra set of holes that you could put shackles in and then use those to tie the anchor bridle to. If not replace the clevis pins at the bridle tangs with shackles that have the same pin dia. as the clevis pins. Look at the triangle the wire bridles make. Make the anchoring bridle a little a little larger.
You can do a search. This topic was talked about a while back.
0 registered members (), 269 guests, and 35 spiders.
