Rebuild a Gibbs Shark #221349
10/09/10 04:42 PM
10/09/10 04:42 PM
Sarasota, FL
Cleric Offline OP
Cleric  Offline OP
Sarasota, FL
I recently picked up a older Gibbs Shark and it is in a fairly sad state. I think that I can bring her back based on some others boats that I have worked on. Any advice on this boat that would help would be greatly appreciated. Thanks!
Hobie TF#166
Hobie 17SE#
Gibbs Shark#?? Sail#US 56
Re: Rebuild a Gibbs Shark [Re: Cleric] #221590
10/13/10 05:30 PM
10/13/10 05:30 PM
Penfield NY
rturbett Offline
rturbett  Offline
Penfield NY
The first thing I would do - Check the inside of the hulls and remove as much of the flotation foam as possible- the ones I have seen with it are totally saturated, making it useless and adding a lot of weight. Lots of ways to replace it if it is important to you.
let us know if you have any questions- no reason why that boat cant float again!
Rob
Re: Rebuild a Gibbs Shark [Re: Cleric] #246844
04/10/12 04:35 AM
04/10/12 04:35 AM
Wil Offline
Wil  Offline
Hi Cleric:
How did you make out with your restoration?
Is your Gibs Shark flying?
Wil
Wil
0 registered members (), 383 guests, and 31 spiders.
