Re: uni vs 2 up. should their rating really be the same? [Re: Cab] #227032
01/18/11 06:59 PM
01/18/11 06:59 PM
Darryl_Barrett Offline
WE have found there to be no overal difference in performance results between the two different configurations, the only difference has been in the quality of the sailers. I think that this will once again be shown to be correct at the up coming Australian nationals in a few days time
Darryl J Barrett.
Re: uni vs 2 up. should their rating really be the same? [Re: Darryl_Barrett] #227045
01/19/11 08:04 AM
01/19/11 08:04 AM
pgp Offline
pgp  Offline
Folks I'm begining to have second thoughts. I'm not willing to try and change the rating or the equipment but maybe we should recognize the top uni with a trophy.
Comments?
Pete Pollard
Blade 702
Re: uni vs 2 up. should their rating really be the same? [Re: waynemarlow] #227048
01/19/11 09:22 AM
01/19/11 09:22 AM
Maryland
Kris Hathaway Offline
Maryland
Originally Posted by waynemarlow
Equal handicap but the Uni's should be able to run a small jib as well to compensate for the lack of 4 hands. cool
Absolutely, the ratings need to be the same. This is a class foundation. However, the sail configuration needs to handicap single and double handed accurately.
I race primarily uni but have done a couple with inexperienced crew. The jib effect is valid. Much more power and greater righting moment in tandem with the newer hull designs more than offset the additional crew weight.
I am opposed to structural design modifications to optimize uni configuration; ie. smaller hulls because the boat will loose its 1 or 2 up flexibility which is a differentiating quality of the class that also must be preserved. That leaves us with sail development.
I agree with Wayne that simply dropping the jib may not be a valid equalizer either. It may have been with the early generation hulls. Whatever the case, not enough racing/development has been done with top racers using a uni-cut main to justify even exploring adding a small jib with reduced main.
Ironically, I believe the manufacturers would sell more boats and sails if sail development (and rules if needed) allow unis to be more competitive at the regional/national/world events.
Kris Hathaway
Re: uni vs 2 up. should their rating really be the same? [Re: pgp] #227050
01/19/11 09:25 AM
01/19/11 09:25 AM
I'm happy with the Rum award.
If you really want to spend money on trophys, you could go 3 deep in both Sloop and Uni, and 3 deep overall as well, the first 3 boats overall would get two trophys, one for First place overall, and one for which ever configuration he was.
OR...race and score all as one fleet and then give out 6 total trophys, 3 deep for Sloop and uni.
But like I said above, as a Uni guy, I'm happier with the rum, paid for by the other Uni racers!
If we ever got say, 60 boats, 30 of each configuration, to show up at a big event (Nationals or Worlds) then perhaps separate starts/awards for Sloops and Uni's, but we are a long way from that.
Re: Trophies [Re: Timbo] #227056
01/19/11 11:23 AM
01/19/11 11:23 AM
Maryland
Maryland
+1...and probably the most appropriate solution for "Uni" trophy, though we have some non-rum (whiskey or dry) uni racers. Of course, last year I was given a manikin's arm as a "single handed" trophy. Still in Ed's garage if it hasn't sold yet.
Kris Hathaway
Re: Trophies [Re: Kris Hathaway] #227060
01/19/11 01:16 PM
01/19/11 01:16 PM
Nice!
Now, if only the arm were holding a 12yr. old bottle of Bushmills!
Re: uni vs 2 up. should their rating really be the same? [Re: pgp] #227064
01/19/11 03:29 PM
01/19/11 03:29 PM
I'm all for it !
Re: uni vs 2 up. should their rating really be the same? [Re: Wouter] #227080
01/19/11 05:11 PM
01/19/11 05:11 PM
waynemarlow Offline
waynemarlow  Offline
Alcohol only dulls the senses, it doesn't solve the problem. Certainly interested in how Daryll gets on and whether his views remain the same over the next year.
0 registered members (), 626 guests, and 34 spiders.
