| cat trax rubber tire going flat #22691 07/29/03 08:40 AM 07/29/03 08:40 AM |
Posts: 552 | One tire had always had a slo leak since new ( 1 year old),..the other tire is fine. Now, it goes flat evry 10 days,.......ideas to fix? IT is not the valve......thanks for your ideas. Bruce St. Croix | | | Re: cat trax rubber tire going flat
[Re: brobru]
#22692 07/29/03 10:30 AM 07/29/03 10:30 AM |
Posts: 833 St. Louis, MO, | It's leaking around the seal of the rim and tire. You can go and have the tire taken off and try to buff the rim around the seal so that it will seat cleaner. What I did was take it to an ATV shop and have them put a tube in mine. It took about 4 years till it leaked again from saltwater corroding the valve stem on the tube. I just had them put another tube in the tire this year. My other tire never has leaked.
YMMV.
Mike Hill H20 #907
Mike Hill N20 #1005
[Re: brobru]
#22693 07/29/03 03:31 PM 07/29/03 03:31 PM |
Posts: 13 | Take to a tire shop and have them fix it. On mine the valve stems leek every couple of years. They just glue them in and I give them $5.
Tim Imlah
Trappinout
H20 - 670
G30 - 242
[Re: trappinout]
#22694 07/30/03 03:37 AM 07/30/03 03:37 AM |
Posts: 744 | Put in a tire tube to both tires. You will have no more problems. Bob
[Re: Mike Hill]
#22696 07/30/03 05:14 PM 07/30/03 05:14 PM |
Posts: 552 | OK! Thanks for the help,........ 1) will look at the valve stem again,.......hope that us ut. 2) No ATV's down here ( park service and police have a few),...but the Inner tube idea sounds great,.......any of you have a link to a dealer that I can buy from and they would throw it in the mail to St. Croix, US Virgin Islands? ....again,...thanks to all,...the tires are real nice when they stay full,....aren't they!!!  Bruce St. Croix USVI | | | Re: cat trax rubber tire going flat
[Re: brobru]
#22697 07/30/03 06:08 PM 07/30/03 06:08 PM |
Posts: 217 | An alternative to inner tube - "fix a flat". Supposedly temporary, but that's for cars - high speeds. Fix a flat is messy inside the tire, so once you do it, if you ever take the tire off, it's a real mess. I think there is a variant called "slime" that's more heavy duty, but doesn't add the weight of foam.fillers. http://www.slime.comThere is also a foam that is used by farmers on things like tractors, and industrial (forklifts) so they never have to worry about flats. Kind takes up the stress even when air pressure doesn't. Downside (for your application) is the weight. http://www.noflat.comhttp://www.fixaflat.com/http://www.otrwheel.com/ff.htm
811
guests, and 24
