| Re: uni fest
[Re: tback]
#227233 01/21/11 04:39 PM 01/21/11 04:39 PM |
Posts: 6,049 Sebring, Florida. | I need dates. Pete, when is the GYC A-F16 regatta (or what ever they are calling it this year) and when is Spring Fever Thanks. You can find dates [HERE] It is also locked as a link at the top of the Open Forum Thanks Terry, and thanks for that great dinner too! Has Chris recovered yet?
Blade F16 #777
| | | Re: uni fest
[Re: TEH]
#228086 02/03/11 09:03 AM 02/03/11 09:03 AM |
Posts: 396 Annapolis Md. | Tom thanks for the idea of using these on the jib track. I've been hesitant to install the track on the Falcon because this type of track leaves the tabs on the beam when the track is removed and the tabs by themselves look painful. Ed
Still hazey after all these beers. F-16 Falcon #212
| | | Re: uni fest
[Re: LuckyDuck]
#228097 02/03/11 02:13 PM 02/03/11 02:13 PM |
Posts: 606 Maryland | I have been thinking about them also. I've been racing with the jib track removed but with the tabs riveted in. Though it looks menacing with the bare tabs, it has never been an issue. The tabs are close enough to center that I do not pass over them while climbing back on board nor do they interfere with any rigging. Can't wait to see your install Ed. Do you even have a jib and crew yet? (Vic is unavailable for the Nationals  ).
Kris Hathaway | | | Re: uni fest
[Re: Kris Hathaway]
#228099 02/03/11 02:20 PM 02/03/11 02:20 PM |
Posts: 606 Maryland | BTW, stainless or aluminum (paper or plasic) rivnuts? My understanding is that aluminum is prefered to minimize corrosion if strong enough for the application. I believe it should and that you would not have to use SS in this case. Yes?
[Re: Kris Hathaway]
#228111 02/03/11 04:42 PM 02/03/11 04:42 PM | Scarecrow
| Scarecrow
Unregistered | If you're using rivnuts to enable you to regularly add and remove a fitting don't use ali. It is too soft and the threads won't last. Go with Stainless or even better Monel. A bit of Tefgel will handle corrosion | | | Re: uni fest
[Re: Kris Hathaway]
#228134 02/03/11 08:08 PM 02/03/11 08:08 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH
Posts: 329 Chicago, Illinois USA | Falcon must have a different track setup. All Karl had on his Viper was a nice neat row of the rounded head nuts screwed into the rivnuts.
I suppose you could have two rivnuts for each tab.
Blade F16 USA 725
| | | Re: uni fest
[Re: Kris Hathaway]
#228198 02/04/11 06:22 PM 02/04/11 06:22 PM |
Posts: 4,119 Northfield Mn | BTW, stainless or aluminum (paper or plasic) rivnuts? My understanding is that aluminum is prefered to minimize corrosion if strong enough for the application. I believe it should and that you would not have to use SS in this case. Yes? I used stainless. It good to coat them with Duralac or something similar when installing. A bit of grease on the threads probably wouldn't hurt either.
| | | Re: uni fest
[Re: Karl_Brogger]
#228204 02/04/11 10:37 PM 02/04/11 10:37 PM |
Posts: 5,525 | Karl was on fire in the last race this afternoon! He did well all day but in the last race he ran away from everyone.
The uni guys need to coax the details out of him.
Pete Pollard Blade 702
550
guests, and 24
