preparation #227349
01/24/11 10:15 AM
01/24/11 10:15 AM
pgp Offline OP
pgp  Offline OP
I have it on good authority that, " a mistake on zee land or a mistake on zee water is still a mistake".
So what do you guys consider absolutely essential in setting up to race?
Pete Pollard
Blade 702
Re: preparation [Re: pgp] #227350
01/24/11 10:50 AM
01/24/11 10:50 AM
M
maritimesailor Offline
M
huge question, even specifically dealing with rigging of the boat / equipment...
off the top of my head, in no real order, please add:
1. Inspection of all blocks (specific attention to spin halyard block)
2. Inspection of all lines, including halyards, tackline, spin pole ties
3. Inspection of anywhere there is a shackle, similarly with split rings
4. Batten tension / ties
5. Rudders / Boards for dings, etc (Rudders also for attached hardware)
6. Boom and spin pole for wear / cracks, specially anywhere there is a hole drilled in it
7. Trap lines inc bungies
8. Mast rake
9. Shroud tension (appropriate for expected starting weather)
10. Diamond tension (same as above)
11. Water in the hulls, drain, garbage, etc
12. Reset all continuos lines to be centered (do between races as well)
Most of these can be done at the end of a day of sailing en lieu of before sailing.
end of day also ice crews forearms ;-)
Re: preparation [Re: maritimesailor] #227356
01/24/11 11:39 AM
01/24/11 11:39 AM
M
MN3
MN3
M
my checklist:
rum
ice
wind
Re: preparation [Re: ] #227357
01/24/11 11:43 AM
01/24/11 11:43 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Originally Posted by MN3
my checklist:
rum
ice
wind
If you have enough of the first 2 the 3rd really doesn't matter.
Isak Dinesen
E. B. White
Re: preparation [Re: Team_Cat_Fever] #227358
01/24/11 11:45 AM
01/24/11 11:45 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
my checklist:
rum
ice
wind
with enough of the first, the second doesn't matter either!
Re: preparation [Re: pgp] #227359
01/24/11 11:46 AM
01/24/11 11:46 AM
Re: preparation [Re: Tony_F18] #227361
01/24/11 11:53 AM
01/24/11 11:53 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Jake......read carefully! grin
Re: preparation [Re: ksurfer2] #227365
01/24/11 12:00 PM
01/24/11 12:00 PM
Beachwheels and sandwiches optional. Quote of the regatta by Karl "What the hell is he doing?"
Isak Dinesen
E. B. White
Re: preparation [Re: ksurfer2] #227367
01/24/11 12:03 PM
01/24/11 12:03 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Bitch, that was cold! Funny, but cold.
F18 USA 242
http://www.solarwind.solar
Re: preparation [Re: Tony_F18] #227368
01/24/11 12:09 PM
01/24/11 12:09 PM
Don't ask me how I know.... smile
Re: preparation [Re: waterbug_wpb] #227372
01/24/11 12:30 PM
01/24/11 12:30 PM
brucat Offline
brucat  Offline
McLube traveler tracks and cars, as well as sail tell-tales.
Tape all ringdings. Check them all twice.
If you don't have wind, you'll definitely need more rum (I suppose the converse is also true).
Re: preparation [Re: brucat] #227373
01/24/11 12:35 PM
01/24/11 12:35 PM
Clermont, FL, USA
Clermont, FL, USA
Isn't the thinking now that McLubing traveler tracks and cars is bad because there is a build up on the ball bearings causing them to stick and get out of round?
Taping ring dings cannot be understated!
F18 USA 242
Re: preparation [Re: brucat] #227376
01/24/11 01:15 PM
01/24/11 01:15 PM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
I would not put Sailkote on the traveler tracks and cars. SailKote is so slick that the bearing will not roll and they will eventually get flat spots on them. I would recommend that you use McLube OneDrop since it is actually designed for bearings and works quite well.
I know all about the flat spotting problem because the previous owners of my Nacra 20 used Sailkote on the traveler bearings and I had to replace them.
Bo Kersey
Corsair 31-1D 276
Re: preparation [Re: ksurfer2] #227378
01/24/11 01:29 PM
01/24/11 01:29 PM
You beat me to my "AMEN!" on that one! grin
Re: preparation [Re: BoK] #227379
01/24/11 01:32 PM
01/24/11 01:32 PM
I wasn't a big fan of putting anything on travler car bearings until I first used the "One Drop" product (Harken or McLube?). It works magic on recirculating bearings...and the company I work at has a proprietary dry conveyor lubricant (that is mineral oil based) that works really well and lasts longer than the one drop....I use it on traveler bearings and beach cat wheels.
Re: preparation [Re: Jake] #227380
01/24/11 01:33 PM
01/24/11 01:33 PM
pgp Offline OP
pgp  Offline OP
Details!?
Pete Pollard
Blade 702
Re: preparation [Re: pgp] #227398
01/24/11 03:23 PM
01/24/11 03:23 PM
brucat Offline
brucat  Offline
Interesting points about SailKote. My H16 had sliding jib cars (no bearings), so that was never an issue.
The main traveler used spindle bearings, no problems there either. I also used it on my main (Harken, BB) blocks, never had an issue.
Probably the best place I used it (as a lube for running rigging) was the line and corner casting cheek blocks for the jib traveler.
Re: preparation [Re: pgp] #227422
01/24/11 06:16 PM
01/24/11 06:16 PM
Details!?
If you are asking about the dry lubricant (dry is a little bit of a misnomer)...I can sell it to you in 5 Liter containers at about $500 each. If I get time this year from major projects, we may pursue some distribution opportunities to get it into smaller, sell-able, quantities for sailing. For the time being, I have a small squirt bottle that I carry with me at regattas for myself...be glad to share if you want to try it out.
0 registered members (), 309 guests, and 102 spiders.
Posts267,056
