| Re: Trailering an F18 by the beams (like an A Cat)
[Re: wildtsail]
#229544 03/09/11 07:57 PM 03/09/11 07:57 PM | Scarecrow
| Scarecrow
Unregistered | trailering by them beams is increasingly popular because it protects the bottom of the hulls. However....
The foward beam-hull connection is designed to be in compression and shear, when you hang the hulls off the beam this puts the whole thing in tension. With a 30kg+ hull hanging from this joint and vibrating as you go down the road at 60 mph you are definately softening/fatiguing this crucial area, particularly an issue with a polyster boat. | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: ]
#229548 03/09/11 09:06 PM 03/09/11 09:06 PM |
Posts: 3,293 Long Beach, California | Not recommended for an F18 - heavy hulls. A-cat? No problem - glued beams and very light loads.
[Re: wildtsail]
#229602 03/10/11 10:49 PM 03/10/11 10:49 PM | Scarecrow
| Scarecrow
Unregistered | Then go for it. From my point of view a few scratches in the hull bottoms can be filled and sanded. Once your deck goes soft it is time to sell the boat. | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: C2 Mike]
#229620 03/11/11 11:56 AM 03/11/11 11:56 AM |
Posts: 756 Newport, RI | Wow...that was uncalled for... wake up on the wrong side of the bed this morning? The 2nd half of your post is appreciated, I didn't know Greg trailered like this. I've never seen anyone do this with an F18. I asked for opinions and never stated mine until I could be objective in search for more opinions. I'm not an engineer and the person I talked to that said it would be fine was an engineer and designer at Hobie for a long time. I've done plenty of trailering with cradles and my hulls are in fine shape, I'm just looking at options.
[Re: macca]
#229833 03/16/11 10:46 AM 03/16/11 10:46 AM |
Posts: 172 Anacortes | The sailing loads are much more than you would ever see on a trailer even if you jumped off speed humps!!
I'm visualizing some sort of side game and some wagers for the parking lot at NA's...
Anacortes Rigging.com Rigging and Yacht Services
[Re: maritimesailor]
#229858 03/17/11 12:11 AM 03/17/11 12:11 AM | Scarecrow
| Scarecrow
Unregistered | I've also thought of this but have been scared to try it as I have only seen it with a-cats... so you go ahead and let me know ;-) Knowing Greg does this, and also with the blessing of Macca helps though. With those two saying you can I think you could get away with it. Would make for a really clean trailer... should look good. How long do Macca and Greg keep their boats? Just saying. | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: macca]
#229860 03/17/11 03:15 AM 03/17/11 03:15 AM | Scarecrow
| Scarecrow
Unregistered | In an ideal world you'd do both. Travel on hull pads and store on the beams. Ironically if anything people tend to do the reverse. | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: ]
#229962 03/19/11 01:02 PM 03/19/11 01:02 PM |
Posts: 756 Newport, RI | Trailex makes a trailer for A Cats http://www.trailex.com/TX-418-ACAT.cfmI was thinking about doing similar but making a groove for the striker to slide into so that the load is on the beam and not the striker. I haven't made up my mind, both sides have convincing arguments. I may rig it up and see how the hulls like it. | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: wildtsail]
#230601 03/31/11 09:04 PM 03/31/11 09:04 PM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | my stingray ( like an 18ft tornado) sits on the trailer by the beams sitting on forward running rails about 1/2 inch inside the hulls. and we have our beams enclosed in the hulls, not bolted onto the decks. so if there was a problem, we would be the first to NOT do that, as its very difficult to replace a beam. my boat is at least 20 years old, original beams and decks and my platform is still very stiff, no twisting whatsoever. the wider you can make the frame for your beams to sit on, the better. much like the picture by trailex for the a class. however we have a system where the rails can be lowered at the back to make it easier to remove boat from trailer. it slides down the carpeted rails and onto your beach rollers. it also allows you to fit a sailbox to the trailer as the boat sits a little higher above the box.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
[Re: Sloansailing]
#231382 04/20/11 09:11 PM 04/20/11 09:11 PM |
Posts: 1,911 South Florida & the Keys | I have often considered storing cats in the yard by the beam so that weather and airborne dirt can't accumulate between the cradles and the boat but I can't imagine that trailering between here and there will cause any problems in either configuration. Butt, what do I know......
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: davefarmer]
#231571 04/27/11 06:50 AM 04/27/11 06:50 AM |
Posts: 606 Maryland | I looked closely at a setup this past weekend that used rails a la A-Cat for a boat with a striker. The cat is loaded backwards so that you did not have to slide on the rails with the striker. Section where the front beam rests (back of trailer) had notches cut in the rails to accommodate the striker. He has even used it to trailer an N20 with no issues.
Kris Hathaway | | | Re: Trailering an F18 by the beams (like an A Cat)
[Re: Kris Hathaway]
#231574 04/27/11 07:53 AM 04/27/11 07:53 AM |
Posts: 1,383 Kingston SE South Australia | When I had the Stingray I made little trolleys that ran on the rails so that I could place the beam on the rollers and slide it with no damage. Still have them in the shed if you need a photo. My Taipan 5.7 travels 8,000km a year hanging on its front & rear beams.
1 registered members (Seanziepop),
676
guests, and 84
