Hurricane 4.9 #235411
07/29/11 01:04 PM
07/29/11 01:04 PM
AntC Offline OP
AntC  Offline OP
Hi all
i have just acquired a hurricane 4.9 and am after some info.
firstly i need a jib for it. does anyone know where i may be able to get a jib or have a picture of a jib so i can estimate a design. did the jib take any of the rig tension or was it a hank on?
and secondly one of the rudders needs replacing. the white formula guys have said that the rudder is not made anymore but it is the same shape as a tornado rudder. so if any one has any info on where i can get a second hand blade that would be amazing.
regards
Ant C
Re: Hurricane 4.9 [Re: AntC] #235433
07/29/11 03:12 PM
07/29/11 03:12 PM
Do you definately have a 4.9? that was originally the Condor but changed to a 4.9 when White Formula bought the moulds. AFAIK it didn't use Tornado rudders though. I think the 5.9 did use T rudders.
Re: Hurricane 4.9 [Re: Jalani] #235440
07/29/11 04:30 PM
07/29/11 04:30 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Grant at G P sails produced the last of the condors just before it changed to the 4.9 and he has lots of tornado bits - try him
Re: Hurricane 4.9 [Re: AntC] #235478
07/30/11 09:40 AM
07/30/11 09:40 AM
UK
Cheshirecatman Offline
UK
Originally Posted by AntC
Hi all
regards
Ant C
The answer depends to some extent on whether the boat was built as a Condor or upgraded (as a lot were). As far as I know the boats from s/n 999 were foam sandwich boats with the 5.9 system. The boats built as 4.9s (from approx s/n 1046) should also have this system. I understand that there may be exceptions to this as I think John Mazzotti may have passed the rights to IYRU/ISAF and home build may still have been possible. Earlier boats had a very 'square' rudder blade.
Cheshirecatman
Re: Hurricane 4.9 [Re: AntC] #235505
07/31/11 08:10 AM
07/31/11 08:10 AM
AntC Offline OP
AntC  Offline OP
Hi
I am sure its a 4.9 as it has 'hurricane 4.9 white formula on the side. i have taken a photo of the other rudder so if anyone recognises it please let me know.
the jib has a wire halyard and a 4mm forstay, both capable of taking tension but need to know weather the jib i get made needs a wire luff.
cheers all
Re: Hurricane 4.9 [Re: AntC] #235514
07/31/11 04:18 PM
07/31/11 04:18 PM
I THINK that the 4.9's had Hurricane 5.9 rudders with different stocks and arms as the setup was different; Grant Piggot WILL be able to help.
ww.gpsails.com
0 registered members (), 268 guests, and 25 spiders.
