| Scaling up to 14 feet #237328 09/08/11 06:51 PM 09/08/11 06:51 PM |
Posts: 16 | What would be the downside,if any, of taking the DS12 plans and simply adding 16 percent to every dimension of every part? This should yield a boat that is 14'long with a 7'beam and all dimensions would be proportionate to the DS12.
| | | Re: Scaling up to 14 feet
[Re: Dewey]
#237338 09/09/11 04:35 AM 09/09/11 04:35 AM |
Posts: 1,383 Kingston SE South Australia | I'm no boat designer but the stresses change a lot on a design when you add length to it, especially in front of the main beam. Darryl Barrett and Berny on the F14 forum have some great F14 designs and the hulls are the cheapest part by a long way.
[Re: JeffS]
#237339 09/09/11 05:28 AM 09/09/11 05:28 AM | Scarecrow
| Scarecrow
Unregistered | There is good news and bad here.
The bad is photocopier boat design doesn't work. The good is if it did I wouldn't have a job.
If you just scaled everything up equally the displacement would be wrong. For example if you make everything 10% bigger the boat's volume goes up by over 30%. You could just stretch the boat to 14ft but it probably still won't float right so you then need to scale beam and depth. Generally these need to kept in proportion to each other for the shape to work and now unless you have suitable software you can't use the existing geometry for hull sheets etc.
You 14ft boat will be faster than the ds12 so the foils can be reduced in size in proportion to the square of the increase in speed.
If you are using a trap and have more righting moment you'll need to scale the dagger boats up to tailor for the increase side force.
If your mast is taller you end up with a higher heeling moment for a given side force so you can scale the foils back down.
Unless you've scaled the rudders the same amount as the daggers your clr has now moved so you'll need to either resize them or move the daggers for or aft.
Etc etc. It is possible and may be an interesting project. But you might be better off starting from an existing design at the right size and tweaking instead of scaling. | | | Re: Scaling up to 14 feet
[Re: ]
#237341 09/09/11 06:27 AM 09/09/11 06:27 AM |
Posts: 16 | Thanks for the replies. There is quite a bit that goes into designing a boat that I am totally ignorant about, which is why I asked. I was just curious about the effects of scaling up a given design more than anything else.
718
guests, and 178
Mod | | Forums26 Topics22,405 Posts267,056 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
