Re: F18 and H16 Double Stack [Re: David Ingram] #242066
01/04/12 06:56 PM
01/04/12 06:56 PM
Ocean Springs, MS
kmboudreaux Offline
kmboudreaux  Offline
Ocean Springs, MS
I have a F250 and a 30' 5th wheel and pull my F18 Tiger behind my 5th wheel. I've been doing this for 6 years and never had a problem. You can't back up both trailers, so if you get in a bind...just unhook the boat trailer. Also, you need to travel a bit slower. The only thing I find is the boat bounces a bit more behind the 5th. Don't worry about turning extra wide...the boat will follow the 5th wheels track perfectly.
Kenny Boudreaux
C2 F18
Goodall Designs/Southern Area Rep
www.sailboxes.com
Re: F18 and H16 Double Stack [Re: brucat] #242074
01/04/12 10:12 PM
01/04/12 10:12 PM
Originally Posted by brucat
Originally Posted by Jake
I believe that the National Laws govern tandem trailers on the interstate system...and it's allowed as long as you're under 65'. When you get off the interstates is when the state laws come into play. Note, however, I believe all require that the first trailer be a 5th wheel trailer (with the goose neck hitch that connects over the tailgate into the bed of the truck...or a semi truck arrangement).
http://www.hitchemup.com/statetowinglaws.htm
Thanks, I think that was the link that I was looking for.
Not sure if it's the feds or states (or some combination) that make the rules, but they are enforced by state officials (not feds). Tandem trailers are most definitely not allowed in all states, on or off the interstate.
It's sort of a moot point. If tandems are only allowed on the interstate, how would you get to the beach?
Several freight companies use tandem semi-truck trailers (UPS, FedEX, DHL, etc.) I was nearly certain they were allowed to pass through all states on the freeway in that arrangement.
Re: F18 and H16 Double Stack [Re: Jake] #242075
01/04/12 11:52 PM
01/04/12 11:52 PM
catman Offline
catman  Offline
Fla. rules.
link
Re: F18 and H16 Double Stack [Re: Jake] #242076
01/05/12 12:06 AM
01/05/12 12:06 AM
brucat Offline
brucat  Offline
"Several freight companies use tandem semi-truck trailers (UPS, FedEX, DHL, etc.) I was nearly certain they were allowed to pass through all states on the freeway in that arrangement."
We see them in NY too. But when they get to the MA border, they have to unhook the second trailer before they cross the border. A second tractor has to come out to drive the extra trailer into MA. There are special lots for this on the interstates right near the borders.
Personally, this seems silly to me (if they're allowed in some states, they should be allowed in all, especially if we're only talking interstates here), but politics is what makes life interesting (to somebody, I guess)...
Re: F18 and H16 Double Stack [Re: David Ingram] #242077
01/05/12 07:02 AM
01/05/12 07:02 AM
Pulling a double bottom catamaran setup sucks. Too light, with too much windage.
Re: F18 and H16 Double Stack [Re: David Ingram] #242081
01/05/12 10:52 AM
01/05/12 10:52 AM
Originally Posted by David Ingram
If sweetness is going Hobie, who's going to keep you from getting spat out the back of the F18 fleet?
Mark "I'm Batman" Herendeen
Well, that helps.... The cape might slow you down though
Re: F18 and H16 Double Stack [Re: brucat] #242082
01/05/12 10:54 AM
01/05/12 10:54 AM
I believe in FL that doubles are allowed on interstate (but not triples). Once you need to get on smaller highways/surface streets, it's not very practical to pull doubles anyway. Trailer interchange yards make it relatively easy to transition to/from doubles.
But, overall, it's still cheapest to haul stuff by water, then by rail, truck, and air. So just sail those things down and you're all set, right? smile
Re: F18 and H16 Double Stack [Re: David Ingram] #242115
01/06/12 10:08 AM
01/06/12 10:08 AM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Just put some dense foam cushions on top of the F18 and then throw the H16 on top. Works great as you can see from the photo.
Bo Kersey
Corsair 31-1D 276
Re: F18 and H16 Double Stack [Re: BoK] #242117
01/06/12 10:34 AM
01/06/12 10:34 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
Hobie and AHPC trailered together mass hysteria.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: F18 and H16 Double Stack [Re: David Ingram] #242118
01/06/12 10:36 AM
01/06/12 10:36 AM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Kinda looks like they are mating, doesn't it.
Bo Kersey
Corsair 31-1D 276
Re: F18 and H16 Double Stack [Re: BoK] #242119
01/06/12 10:46 AM
01/06/12 10:46 AM
Clermont, FL, USA
David Ingram Offline OP
Clermont, FL, USA
It doesn't get simpler than that. I also have a couple of $$ for you, I'll find you at Tradewinds.
F18 USA 242
http://www.solarwind.solar
Re: F18 and H16 Double Stack [Re: David Ingram] #242120
01/06/12 10:53 AM
01/06/12 10:53 AM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Yeah, we tend to over analyzed these things while sitting at the desk. If you just go out in the driveway and do it, you'll figure it out smile
Bo Kersey
Corsair 31-1D 276
Re: F18 and H16 Double Stack [Re: David Ingram] #242122
01/06/12 11:52 AM
01/06/12 11:52 AM
Klozhald Offline
Klozhald  Offline
Two thoughts:
Did you consider reversing the H16 on top so that the lower part (the rear) of the tramp faces the wind while you are driving?
Go to an electronics dept store and ask around back if you can have some of the large styrofoam blocks that components and appliances come packed in to use to pad between the upper and lower hulls.
Sheet In!
Bob
Bob - Mesa AZ USA
Prindle 18-2 #244 "Wakizashi"
Training for the Anacapa Tri-Point Race Summer 2012
Re: F18 and H16 Double Stack [Re: David Ingram] #242124
01/06/12 12:39 PM
01/06/12 12:39 PM
brucat Offline
brucat  Offline
The foam thing looks like a great option.
I bet the 2x4 idea started way back when there were no cats but H14s and H16s. You know, before foam was invented...
I know for sure that I was using it before using the internet.
whistle
Re: F18 and H16 Double Stack [Re: Klozhald] #242125
01/06/12 01:48 PM
01/06/12 01:48 PM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
Yeah but then the mast would have to be low in the front and high in the back and would hit the car smile
Originally Posted by Klozhald
Two thoughts:
Sheet In!
Bob
Bo Kersey
Corsair 31-1D 276
Re: F18 and H16 Double Stack [Re: David Ingram] #242126
01/06/12 02:28 PM
01/06/12 02:28 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
"Kinda looks like they are mating, doesn't it."
And after the deed is done the C2 eats the Hobie...lol
Re: F18 and H16 Double Stack [Re: BoK] #242127
01/06/12 03:00 PM
01/06/12 03:00 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Is that a Hobie condom on the end of the mast?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: F18 and H16 Double Stack [Re: brucat] #242154
01/08/12 09:09 AM
01/08/12 09:09 AM
whistle
You're exactly right. Nailing a couple of sets of small "risers" to the bottom of the forward 2x4 was necessary to compensate for the beam curvature. Rear cross-2x4 can be a single piece.
Slap some carpet on it and you're done. (note - bottom H16 facing forward and top H16 bows to rear, or you're really popping-a-wheelie!)
I did the packing foam and swim noodles thing to take an H17 & TheMightyHobie18 to NAC's last spring. Cheap and functional.
Found that I needed to tie from the bow tangs of the H17 to the mast stand.
In big cross wind, top boat would eventually work itself off center (no matter how well was tied to bottom boat)
0 registered members (), 698 guests, and 111 spiders.
Posts267,056
