Awesome design, on a mono no less, 80 degree canting keel? #247544
04/28/12 06:48 PM
04/28/12 06:48 PM
42.904444 N; 88.008586 W
Todd_Sails Offline OP
F-18 Infusion
#626- SOLD it!
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247545
04/28/12 08:17 PM
04/28/12 08:17 PM
I just kinda skimmed over it, (I'm driving), but I've said it before, a few thousand years of man harnessing the wind, and we're just figuring it out.
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247547
04/29/12 03:53 AM
04/29/12 03:53 AM
Just think what happens when you broach with a keel hanging at 80 degrees, cant be good.
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247551
04/29/12 07:24 AM
04/29/12 07:24 AM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
isn't that essentially a catamaran? call it an ama if you like but it sure does sound like a cat to me(odd looking cat).
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247583
04/30/12 06:30 PM
04/30/12 06:30 PM
Mike Fahle Offline
Mike Fahle  Offline
It more accurately could be described as a sliding seat canoe on steroids. The article does reference catamarans and makes the case that this is better because it eiminates the hydro and aero dynamic drags of the other hull. They missed a couple of obvious speed enhancing features - a canting rig and a wing. I think it is interesting how they conveniently left out how they were only copying existing catamaran hull design after gushing about all the go fast features of the hull. However, if it needs to be represented as their original ideas to get the funds to build and sail this thing then that is fine. I am eager to see the results.
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Mike Fahle] #247585
04/30/12 07:32 PM
04/30/12 07:32 PM
They also missed the fact that a catamaran doesn't have to carry around a chunk of lead....hull width to length ratio is incredibly less, prismatic coefficient, etc.
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Jake] #247633
05/01/12 06:00 PM
05/01/12 06:00 PM
Freestyle Offline
Freestyle  Offline
Yeah its weight just for the sake of weight....the flying hull serves more than one purpose. Not to mention how heavy would the mechanism be that manipulates that chunk of lead....
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247647
05/02/12 12:12 AM
05/02/12 12:12 AM
alsail Offline
alsail  Offline
Yup they'll figure out how to make a propellar plane out run a jet,,, just you wait and see ! ! ! ! !! !
Probably heavyer than the chunk of lead....
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Todd_Sails] #247648
05/02/12 12:15 AM
05/02/12 12:15 AM
alsail Offline
alsail  Offline
so what happens when they get the chunk of lead stuck to one side do they stay on that tack and go in circles or ,or, or,
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: alsail] #247651
05/02/12 06:21 AM
05/02/12 06:21 AM
hope for a wind shift.
Re: Awesome design, on a mono no less, 80 degree canting keel? [Re: Capt_Cardiac] #247700
05/03/12 10:44 AM
05/03/12 10:44 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
There's an article on Sailing Anarchy archives where they demonstrate that the final stage of development of a canting keel monohull is a proa. Seach for "proa" in SA.
This boat is almost there: cant 10 degrees more (to 90 deg) and add enough flotation for the bulb to have neutral flotation and it becomes a proa.
We have discussed here that monohulls are following an evolutionary path towards multihulls. This boat is a good example. Add floats to the racks of a 49er or Moth and you have another.
Luiz
0 registered members (), 346 guests, and 22 spiders.
