| Re: Daggerboard trunks: What to stick in there (Infusion MK1)
[Re: Uli]
#248948 05/28/12 10:26 PM 05/28/12 10:26 PM |
Posts: 4,119 Northfield Mn | Go to a hardware store and get velcro that already has the adhesive on it, the peel and stick kind. Just use the soft side, cut it to size and stick it in there.
Not as good as epoxying carpet in, but takes very little time, isn't messy, and is dirt cheap to do. Even if you have to replace it once a season there isn't much time involved replacing it the same way.
[Re: Karl_Brogger]
#248988 05/29/12 02:37 PM 05/29/12 02:37 PM |
Posts: 3 | Karl, almost was certain you would answer  Thank you. Will try it and as it is so easy I will do it before I go to Bay City this weekend. Uli | | | Re: Daggerboard trunks: What to stick in there (Infusion MK1)
[Re: Karl Funk]
#248996 05/29/12 08:44 PM 05/29/12 08:44 PM |
Posts: 172 Anacortes | Ian... in the middle of the night... in the middle of the Pacific... We are planting spiders all over the boat for you Karl, not to worry!
Anacortes Rigging.com Rigging and Yacht Services
[Re: Uli]
#248998 05/29/12 09:45 PM 05/29/12 09:45 PM |
Posts: 756 Newport, RI | Uli! Aps sell this white carpet type stuff with adhesive back. I put this on my infusion and 2.5 years later it's still going strong. It made the board tight enough that I never had a need to install those stupid rubber things that keep the board up, the board stayed up on it's own. It was a bit tight unless the board was lubed up (that's what she said!) but what you can do is take a razor and buzz it down a bit. It holds much less sand than regular outdoor carpet and when it does it gets burried so it doesn't affect the board as much. You'll have to scroll down, to V15 Daggerboard Carpet. Once you click the part number the picture goes away or i would have given you the direct link http://www.apsltd.com/c-2868-v15ruddertilleranddaggerboard.aspx | | | Re: Daggerboard trunks: What to stick in there (Infusion MK1)
[Re: Sloansailing]
#249072 06/01/12 11:04 AM 06/01/12 11:04 AM |
Posts: 93 | We can laugh now, but honestly, in 30 years of sailing I have never never had a better fitting, stiffer, smooth running daggerboard trunk/gasket. That said, we would never would have done it this way if we did not have to go to the MKII boards, and I will never do it again.
F18 USA 1273 Andrews 77 (SOLD) Melges 32 (SOLD) Formula18 Olympic 49er (FOR SALE) Always outnumbered - Never outgunned....
[Re: USA1273]
#249077 06/01/12 02:40 PM 06/01/12 02:40 PM |
Posts: 172 Anacortes | I believe you Paul. End product good, process in need of refinement!
546
guests, and 69
