| Prindle 19 furler set-up question #249353 06/07/12 06:09 PM 06/07/12 06:09 PM |
Joined: May 2012 Posts: 8 Seabrook, TX Sailinghoutx OP
Posts: 8 Seabrook, TX | I bought a used Hobie "under the bridle" furler. Has anyone used one of these on a P-19? From just briefly looking, it appears that due to way this furler attaches, once the furler is attached to the bridle wires, the furler will actually bring the sail tack up an inch or two. I'm also guessing I will have to shorten the "upper forestay" by this measurement as well as the length of the upper swivel which is 2 5/8" pin to pin. Does this sound correct? I'm guessing there are a couple of different ways to do this, I just want to keep it as painless as possible.
Morris Covin
Prindle 16 sail #5229 Prindle 16 sail #8647 Current ride; Prindle 19 sail #309
| | | Re: Prindle 19 furler set-up question
[Re: Sailinghoutx]
#249373 06/08/12 07:48 AM 06/08/12 07:48 AM |
Posts: 3,224 Roanoke Island ,N.C. | I did the exact same thing on my P-19 years ago, and as said above, shortened the bridles. If you want to switch back or to something else it's easier that way.
[Re: Sailinghoutx]
#249379 06/08/12 11:40 AM 06/08/12 11:40 AM |
Posts: 1,403 | Did this on a Prindle 18 years ago, and ended up going to the Harken setup which I feel was a cleaner application.
Your going to need to shorten the upper forestay along with the pigtail as well to accommodate the top roller barrel along the bridal wires. I believe we went with 2.25" on the bridals and 3.5 on the upper forestay pigtail
Give Joel @ Murrays a shout. He keeps an encyclopedia on this stuff and can hook you up with all the messurments
346
guests, and 22
