Re: Cross cut Mylar vs radial cut mylar. GO! [Re: ] #252692
09/25/12 08:45 AM
09/25/12 08:45 AM
M
MN3
MN3
M
here is what my new main looks like
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: PTP] #254555
11/11/12 06:09 AM
11/11/12 06:09 AM
stormdog777 Offline
stormdog777  Offline
Looking for advice ,,, I have read the sail reviews here , and also will order a new set of sails , for my 18 sq ,which i am going to upgrade to run a jib and spin ,,However im told the F i8 main sail will fit the 18 sq 30 ft mast ,Can any one confirm this ,,or help me find ,Where can i get the sail plans for the F 18 ??
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: AzCat] #254676
11/13/12 09:50 AM
11/13/12 09:50 AM
M
MN3
MN3
M
f18 sails fit very well on my 30' mystere mast
I purchased 2 used ones for around $500 each (one was heavily used, the other was an older model that had a repair from crew going through it during a capsize).
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: stormdog777] #254677
11/13/12 10:36 AM
11/13/12 10:36 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Originally Posted by stormdog777
... for my 18 sq ,which i am going to upgrade to run a jib and spin ...
Are you going to add a bridle foil or some sort of bow support before adding these sails?
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: tshan] #254883
11/18/12 05:51 AM
11/18/12 05:51 AM
stormdog777 Offline
stormdog777  Offline
Hi Tom ,,
yes im fabricating a spreader bar that will span between the hulls .this will then fit the two stay fastening points on the hull ,,the spreader will also have a centre point for the jib /fore stay , the spinaker pole will also travel under this and bolt to it for support ..
Steve
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: ] #254884
11/18/12 05:59 AM
11/18/12 05:59 AM
stormdog777 Offline
stormdog777  Offline
are the f 18 sails you have smaller in luff ? my standard main is 28ft 9 in but a f18 main im told is 26 ft 7 inches ,, ???
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: AzCat] #254952
11/19/12 01:52 PM
11/19/12 01:52 PM
M
MN3
MN3
M
26.7 seems more correct to me
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: ] #255150
11/23/12 11:57 PM
11/23/12 11:57 PM
stormdog777 Offline
stormdog777  Offline
Hi ..just been looking at youre new main sail,,it looks great ,,who made it for you ,,what was the cost ,and delivery time ?? Thanks
Steve
Re: Cross cut Mylar vs radial cut mylar. GO! [Re: AzCat] #255179
11/26/12 09:05 AM
11/26/12 09:05 AM
M
MN3
MN3
M
Doyle made it, took about 3 weeks, $1350
0 registered members (), 515 guests, and 37 spiders.
