Page 1 of 3 1 2 3
curved traveler track #253755
10/22/12 07:58 AM
10/22/12 07:58 AM
pgp Offline OP
pgp  Offline OP
If I took the stock traveler from my Blade and had it curved, how long would it be tip to tip? You can tell my math is non-existent.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253756
10/22/12 08:12 AM
10/22/12 08:12 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
It would still be the same length.
Re: curved traveler track [Re: pgp] #253758
10/22/12 08:50 AM
10/22/12 08:50 AM
pgp Offline OP
pgp  Offline OP
True. I guess I'm looking for the width of the arc.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253761
10/22/12 09:22 AM
10/22/12 09:22 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Re: curved traveler track [Re: pgp] #253762
10/22/12 09:40 AM
10/22/12 09:40 AM
pgp Offline OP
pgp  Offline OP
Thanks.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253764
10/22/12 12:00 PM
10/22/12 12:00 PM
But why?
Re: curved traveler track [Re: pgp] #253765
10/22/12 12:09 PM
10/22/12 12:09 PM
pgp Offline OP
pgp  Offline OP
I'm considering modifying my Blade into a small tri.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253802
10/23/12 01:25 PM
10/23/12 01:25 PM
Pete, dragging me underneath the boat does not make it a tri!
Re: curved traveler track [Re: pgp] #253806
10/23/12 02:15 PM
10/23/12 02:15 PM
Sacrilege!
Re: curved traveler track [Re: pgp] #253809
10/23/12 03:23 PM
10/23/12 03:23 PM
pgp Offline OP
pgp  Offline OP
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253818
10/23/12 05:11 PM
10/23/12 05:11 PM
Scarecrow
Scarecrow
Isn't there an old (non competitive) A class or a hobie 18 or something that could die for the cause?
Re: curved traveler track [Re: pgp] #253820
10/23/12 05:59 PM
10/23/12 05:59 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I curved the traveller on my old A Class, when you curve the traveller bar it's shorter accross the boat but none of the A classes travellers go right to the edge anyway. There is a good advantage to be had from curving it on just the right arc as you don't need as much sheet to let out down wind, disadvantage is clutter on the deck getting in and out over the track and if your arc is wrong the traveller won't flow out smoothly without letting of sheet. It's very hard to curve annodised track yourself with a smooth curve as it has holes in the track which create week points so be carefull (don't ask me how I know). The length from tip to tip will depend on the arc you want below your boom, with your mast as far forward as you will ever use it mark where your boom is over your decks then bring your traveller a bit inside that so your blocks are always pushing the boom toward the mast not trying to pull it away.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: curved traveler track [Re: JeffS] #253867
10/24/12 04:10 AM
10/24/12 04:10 AM
waynemarlow Offline
waynemarlow  Offline
Go Pete, all for a Tri as we get a little older, looking foward to dicing Bitsa up and fitting a 20ft Main hull in a couple of years when trapezing and the likes all starts to get not as enjoyable.
The alternative is to join the Flying 15 squad at the club and I'm really really not sure about that just yet.
Re: curved traveler track [Re: pgp] #253899
10/24/12 06:13 PM
10/24/12 06:13 PM
JeffS Offline
JeffS  Offline
There's a thread on here somewhere which shows my old broken Tornado's good hull became the main hull of a Tri between Hobie Tiger hulls, was built so that he could sail it as a F18 or booze cruise with the mates on the Tri just by bolting on the beams of the day. No reason you cant have your F16 and Tri. Longer beams, centre hull the size you want, couple of tramps and your away, a long crossbar and you even have trendy ama rudders. Get Dcarls to help you with lifting foils and your good to go.
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: curved traveler track [Re: pgp] #253903
10/24/12 07:15 PM
10/24/12 07:15 PM
pgp Offline OP
pgp  Offline OP
Great minds think alike.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253919
10/24/12 11:10 PM
10/24/12 11:10 PM
JeffS Offline
JeffS  Offline
My old Light weight sharpie is the perfect boat for the sit in hull on a tri with 16ft ama's
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: curved traveler track [Re: pgp] #253924
10/25/12 04:50 AM
10/25/12 04:50 AM
pgp Offline OP
pgp  Offline OP
Sharpies are great boats.
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253925
10/25/12 05:04 AM
10/25/12 05:04 AM
JeffS Offline
JeffS  Offline
I'm not so fond of them which is why I sold that one for $300, 3 people trying to balance a canoe with a spinnaker, but for what you want to do that narrow hull would be a fast relatively dry boozer cruiser tri ****
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: curved traveler track [Re: pgp] #253927
10/25/12 07:15 AM
10/25/12 07:15 AM
pgp Offline OP
pgp  Offline OP
Any home build plans out there?
Pete Pollard
Blade 702
Re: curved traveler track [Re: pgp] #253934
10/25/12 09:34 AM
10/25/12 09:34 AM
waynemarlow Offline
waynemarlow  Offline
There are some, have a look on Boat Design where this subject has been discussed at long length at various times, there was a really good thread on a 20 foot racing tri using an A class or F18 hulls as the donor. I think it was a topic by Corey, perhaps search under his user name.
General consenus is that the early beachcat hulls are not good donors being too heavy and too little bouyancy foward of the front beam ( remember a tri has its bouyancy a long way foward to prevent the diagonal pitch poling which is the way most tris go over ). My guess is that the Blade will be better but you may need to step the hull foward further than a dedicated AMA.
Sadly I had decided that the need for a cuddy of some kind and some over nighting would be planned that I gave up on the idea of a Weta on steroids and was probably not what I needed. Went the whole way and have now bought a set of F85SR plans, hope to get started in the new year but then I have been saying that for a long time cool
Page 1 of 3 1 2 3
0 registered members (), 741 guests, and 84 spiders.
Posts267,056
