Aussie Nacra Nationals 2018-2019
by Ventucky Red. 07/19/18 12:47 PM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
F16 Effect Crew Weight Solo and 2 Up
by tback. 06/25/18 08:56 AM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
Page 3 of 3 1 2 3
Re: My F16 Blade build [Re: Rolf_Nilsen] #257044
02/06/13 05:48 AM
02/06/13 05:48 AM
Rolf_Nilsen Offline OP
Hi Sam,
we are getting closer to diving into foils, but not quite there yet!
I dont remember if sections was included in the plywood plans. What I know have been used as a safe section earlier is NACA0007 for daggers and NACA0012 for rudders. But there is a whole world of sections available and tuning that can be done. A very nice catsailor here sent me profile data for a modified NACA0013 to be used as both daggers and rudders. Then there are DAG sections which are used on quite a few catamaran foils..
Planform is also very important.
Not too much info is available but most in the know-how will answer direct questions on a good day.
We will start with proven sections and planforms and eventually make insets if we build experimental sections later on.
Place your bets and hold your breath smile
Re: My F16 Blade build [Re: Rolf_Nilsen] #257060
02/06/13 10:20 AM
02/06/13 10:20 AM
Once you get the section sorted out, just make them 2 meters long...or longer.
Re: My F16 Blade build [Re: Rolf_Nilsen] #257088
02/06/13 03:48 PM
02/06/13 03:48 PM
2 meters!! Bethewaite was on to something but pulled out before it became ridicilous!
Re: My F16 Blade build [Re: Rolf_Nilsen] #257098
02/06/13 05:07 PM
02/06/13 05:07 PM
Scarecrow
Scarecrow
Welcome to modern cats, there is a table of standard F18 board sizes here (last page)
Re: My F16 Blade build [Re: ] #257115
02/07/13 04:00 AM
02/07/13 04:00 AM
Thanks for the link. 1965x23x192mm is.. Well, a challenge.
Considering the lower boat and perhaps also crew weight of an F16 a smaller foil is probably the optimum. But the trend is clear. Longer and slimmer foils.. Where is the practical limit and is it only a trend that will reverse in time.. I dont know, but I do think we will continue to see long and slim foils smile
Re: My F16 Blade build [Re: Rolf_Nilsen] #257123
02/07/13 08:34 AM
02/07/13 08:34 AM
pgp Offline
pgp  Offline
Picked this up on SA: " On an older A-Class with smaller transoms, the conversion from straight to curved boards may have a better chance for improvement if rudder winglets are also included in the upgrade.
There's no doubt that curved boards are here to stay. "
http://forums.sailinganarchy.com/index.php?showtopic=144251#entry4037605
I suppose, that if that is true, we should address the issue in the rules.
Pete Pollard
Blade 702
Re: My F16 Blade build [Re: Rolf_Nilsen] #257129
02/07/13 09:45 AM
02/07/13 09:45 AM
Where is the practical limit ?
I would suspect currently, the limit would have to do with the stiffness of the foil using current materials/technology.
Until, that is, I develop "transparent aluminum"
Re: My F16 Blade build [Re: Rolf_Nilsen] #257154
02/07/13 02:36 PM
02/07/13 02:36 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Speaking as a player in the F18 fleet I don't see the daggerboard length trend ever reversing. Granted there is a pretty small window where they pay but that's where the game is being played now. I'm still running the short boards mainly because I like saying "It's not the length of your daggerboard it's how you use it"
F18 USA 242
http://www.solarwind.solar
Re: My F16 Blade build [Re: David Ingram] #257170
02/07/13 03:49 PM
02/07/13 03:49 PM
enzyte baby...enzyte
Page 3 of 3 1 2 3
1 registered members (Gary Fleming), 15 guests, and 281 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
Gato 3
JeffS 3
mmadge 1
tback 1
Topics22,311
Posts266,603
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
