New England 100 2018
by brucat. 07/21/18 12:17 PM
F16 Effect Crew Weight Solo and 2 Up
by samc99us. 07/20/18 01:12 PM
CL258 and CL259 Clamcleats for Trap Harness
by samc99us. 07/20/18 01:11 PM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
Page 5 of 8 1 2 3 4 5 6 7 8
Re: Blade F16 [Re: waterbug_wpb] #257497
02/14/13 10:41 AM
02/14/13 10:41 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Pete,
Sailrocket is a rocketship, literally. They have custom foils because they are reaching custom speeds!!! You're not doing anything crazy with your Blade and standard airfoils designed to operate in turbulent flow are fine (NACA series). Others have generated perhaps better for our cats but these aren't freely available.
Rolf,
Good to know, that makes sense, thank you. You pay a little drag penalty going thicker on the NACA foils, but the advantage is a higher stall angle of attack, which is why you want a NACA0012 on the rudder. You should never approach stall with your dagger boards unless you are doing something wrong with boat handling, so the key there is minimizing drag. On a long board, you may select a thicker foil for structural reasons mentioned elsewhere in this thread.
I've come full circle and decided I would rather go sailing than build foils. I don't have time to repair boards because my layup was insufficient, nor do I want to deal with broken foils 30+ miles from my destination. Finally, I have a hard time justifying my materials cost relative to a set of production blades. Mold cost is staggering for the required materials; this is with free CNC time on a $50K+ machine! Carbon alone is $800 for the pair of long dagger boards!
F18 Infusion
Re: Blade F16 [Re: waterbug_wpb] #257498
02/14/13 10:45 AM
02/14/13 10:45 AM
pgp Offline
pgp  Offline
I was hoping to go with asymetric boards, thinking this would actually give me an advantage!
Remember F16 is a developement class and I'm using first generation boards (and case which will not accept the new boards without modification) while third generation are available.
Pete Pollard
Blade 702
Re: Blade F16 [Re: waterbug_wpb] #257513
02/14/13 01:52 PM
02/14/13 01:52 PM
samc99us Offline
samc99us  Offline
Solo sailing with asym boards is a lot of work in the tacks.
Even double handed I wouldn't want to deal with it. Performance increase is likely mitigated by crew work level.
F18 Infusion
Re: Blade F16 [Re: waterbug_wpb] #257519
02/14/13 04:36 PM
02/14/13 04:36 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Is the shape of the Blade foils acceptable?
I am a firm beliver in the KISS principle.
Keep It Simple Stupid.
If so,cruise down to your local locally owned hardware store and get a Layout Comb. You can get the profile of the foil and then lay it out on a piece of sheel metal and cut to shape. This gives you a template to shape your foil to.
Re: Blade F16 [Re: waterbug_wpb] #257520
02/14/13 05:22 PM
02/14/13 05:22 PM
pgp Offline
pgp  Offline
There's an idea, hadn't thought of that.
Pete Pollard
Blade 702
Re: Blade F16 [Re: pgp] #257529
02/15/13 06:11 PM
02/15/13 06:11 PM
waynemarlow Offline
waynemarlow  Offline
Theres been many a debate on assy foils and many attempts to make them work, but then about 1 sailing season on they seem to be replaced with sym foils. On that basis I wouldn't bother.
I've always wondered that with the slight bit of leeway we get and by consequence the boat is a little " crabbed " as it goes along, if you draw those vectors we can see that the normal dagger board has some angle of attack anyway and is creating lift.
I've recently built a carbon ski bike frame from scratch and designed it to be built as simple as possible so that others can copy it. As part of that I simply laid a number of flat layers of carbon on a table to act as the backbone of the frame. I then glued foam to either side and shaped that to give form and depth. I then laid carbon around the profile to give bending strength to the structure. It seemed quite an elegant way to build a very light but strong frame.
Could we not do the same, just lay x number of layers of carbon onto foam, add another layer of foam and compress. Take the block to the CNC man and cut one side, turn over and cut the other. Layup the outer and job done.
Even better there are a number of shops that will cut wing shapes for model aircraft, get them to cut two halves of a wing and glue that to the carbon centre layers.
Re: Blade F16 [Re: waterbug_wpb] #257536
02/16/13 10:37 AM
02/16/13 10:37 AM
pgp Offline
pgp  Offline
I gotta give this a tri!
http://vimeo.com/34164014
Pete Pollard
Blade 702
Re: Blade F16 [Re: pgp] #257560
02/18/13 09:25 AM
02/18/13 09:25 AM
waterbug_wpb Offline OP
Foil "V" shape looks interesting. Might make the form rigid without expensive layups?
Re: Blade F16 [Re: waterbug_wpb] #257563
02/18/13 10:00 AM
02/18/13 10:00 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
That's what a triangle is all about...
Re: Blade F16 [Re: bacho] #257571
02/18/13 11:50 AM
02/18/13 11:50 AM
damn you, geometry!
Re: Blade F16 [Re: waterbug_wpb] #257630
02/19/13 11:17 PM
02/19/13 11:17 PM
C
Charles W Offline
Charles W  Offline
C
What are the standard boards for a blade f16? Mine are similar to those on a taipan
Blade F16 with Viper beams
Re: Blade F16 [Re: waterbug_wpb] #257633
02/20/13 04:45 AM
02/20/13 04:45 AM
Scarecrow
Scarecrow
Charles who built your boat, there are quite a few flavours of blade and it may well have taipan boards. For the record the Taipan, Blade and Viper all have the same mast.
Re: Blade F16 [Re: waterbug_wpb] #257641
02/20/13 10:36 AM
02/20/13 10:36 AM
C
Charles W Offline
Charles W  Offline
C
I believe my boat is Australian built as I live in Singapore, the hull is kevlar with the short boards
Re: Blade F16 [Re: waterbug_wpb] #257642
02/20/13 10:40 AM
02/20/13 10:40 AM
pgp Offline
pgp  Offline
Can there really be a standard board? Since F16 is a developement class the boards can change almost at will.
I prefer to think I have generation 1 boards while others are using generation 3 or higher.
Pete Pollard
Blade 702
Re: Blade F16 [Re: waterbug_wpb] #257643
02/20/13 11:40 AM
02/20/13 11:40 AM
pgp Offline
pgp  Offline
fwiw, my boards extend approx. 21" below the case, and have a chord of about 11 1/2", and are approx. 3/4" thick (that's an eyeball measurement).
It appears to be NACA 0006
Pete Pollard
Blade 702
Re: Blade F16 [Re: waterbug_wpb] #257652
02/20/13 07:58 PM
02/20/13 07:58 PM
C
Charles W Offline
Charles W  Offline
C
does anyone build or sell blade foils these days or are they all home builds?
Re: Blade F16 [Re: waterbug_wpb] #257654
02/20/13 09:27 PM
02/20/13 09:27 PM
I'd be surprised if Matt didn't have the moulds
Re: Blade F16 [Re: waterbug_wpb] #257664
02/21/13 02:15 AM
02/21/13 02:15 AM
C
Charles W Offline
Charles W  Offline
C
Is there an Australian builder still around? just thinking about shipping costs etc
Re: Blade F16 [Re: waterbug_wpb] #257665
02/21/13 02:42 AM
02/21/13 02:42 AM
Scarecrow
Scarecrow
measure your boards and post here (with a photo) so we can work out if they're taipan boards or not then contact ahpc and order either viper or taipan boards. It would also be worth trying windrush, Brisbane cat centre (nacra) and performance sailcraft ( laser/Capricorn 2) and seeing if they can help.
Re: Blade F16 [Re: waterbug_wpb] #257666
02/21/13 02:53 AM
02/21/13 02:53 AM
C
Charles W Offline
Charles W  Offline
C
okay cheers, I'll post the info this weekend after sailing
0 registered members (), 25 guests, and 217 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
brucat 5
JeffS 4
Gato 3
mmadge 1
Topics22,313
Posts266,612
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
