Page 3 of 3 1 2 3
Re: Capsize management in a breeze [Re: northsea junkie] #263761
09/13/13 03:06 PM
09/13/13 03:06 PM
pgp Offline
pgp  Offline
Ronald, I use a similar device but found that kneeling gives a little lower center or gravity. Once my knees are on the bar my waist is above the cross beam. So, you might try shortening the ropes, that worked a little better for me.
None of these things is of help if you get separated from the Boat, whick is my biggest concern.
Pete Pollard
Blade 702
Re: Capsize management in a breeze [Re: rehmbo] #263764
09/13/13 03:51 PM
09/13/13 03:51 PM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
Yes Pete, y're quite right with the little lower center of gravity.
But I found out that searching the bar with my feet is easier in rough wave conditions. When I swing my leg over the center-line, my feets are already close to the bar.
Moreover my feet feel more stable on the bar then my knees and standing gives me a sort of mental boost in the tricky situation of the capseize.
When I arrive in the standing position, I know its done, I'm out of trouble.
Finally I was looking for a method which could also be used when I was hurt (maybe twisted something or even broke something). I hope that this trick will give me the best chances in bad unforeseen circumstances.
ronald
RAIDER-15 (homebuilt)
Page 3 of 3 1 2 3
0 registered members (), 543 guests, and 27 spiders.
