New England 100 2018
by brucat. 07/22/18 12:41 PM
do you carry one of these?
by brucat. 07/21/18 08:59 PM
F16 Effect Crew Weight Solo and 2 Up
by samc99us. 07/20/18 01:12 PM
CL258 and CL259 Clamcleats for Trap Harness
by samc99us. 07/20/18 01:11 PM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
Nacra F16 #267696
12/12/13 04:41 PM
12/12/13 04:41 PM
Brisveagas
Aido Offline OP
Aido  Offline OP
Brisveagas
Aido
Viper 288
Re: Nacra F16 [Re: Aido] #267697
12/12/13 04:43 PM
12/12/13 04:43 PM
Brisveagas
Aido Offline OP
Aido  Offline OP
Brisveagas
Aido
Viper 288
Re: Nacra F16 [Re: Aido] #267700
12/12/13 06:26 PM
12/12/13 06:26 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
are they just dropping the N17 board straight in with a mod to the centre case? nacra probably had a heap of spares after so many broke early on...
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Nacra F16 [Re: Aido] #267701
12/12/13 08:44 PM
12/12/13 08:44 PM
It'd be interesting if you could get a handful of boats together to test it out. Say six total, three with curved, three with canted, and have a regatta where all the sailors alternate boats Alter Cup style.
Re: Nacra F16 [Re: Aido] #267745
12/15/13 10:22 AM
12/15/13 10:22 AM
felixshmak Offline
felixshmak  Offline
Very interesting indeed.
would like to learn more on those sailors feedback
Felix
NACRA F16
Re: Nacra F16 [Re: Aido] #267852
12/19/13 06:18 AM
12/19/13 06:18 AM
N
NacramanUK Offline
NacramanUK  Offline
N
The 2014 version of the Nacra 16 has new design of dagger board case that will accept a straight board or a curved board. This will mean the boat will still comply with F16 box rule with straight boards, but will also be able to have its own class racing with the curved boards as well as being a great feeder boat to the 17 class. The case is also designed to allow for the board to have variable rake.....
Re: Nacra F16 [Re: Aido] #267853
12/19/13 06:56 AM
12/19/13 06:56 AM
N
NacramanUK Offline
NacramanUK  Offline
N
I would post the 2014 Nacra F16 pdf but its to large......please pm me if you want a copy or go to http://www.nacrasailing.com/nacra-f16-updates/
Re: Nacra F16 [Re: Aido] #267854
12/19/13 06:57 AM
12/19/13 06:57 AM
N
NacramanUK Offline
NacramanUK  Offline
N
I have spoken to the design team and the new style cases will be available as retro fit kit in due course...
Re: Nacra F16 [Re: Aido] #267858
12/19/13 08:30 AM
12/19/13 08:30 AM
Our new jib was delivered with that clew plate. Very nice upgrade!
No t-foils on rudders though.
Re: Nacra F16 [Re: Aido] #267954
12/22/13 03:15 PM
12/22/13 03:15 PM
Do the F16 rules allow full AC72 style foils?
Re: Nacra F16 [Re: Aido] #267961
12/22/13 08:46 PM
12/22/13 08:46 PM
Nope. They gotta come out the top. I'm sure there is ways around that with the wording, but the spirit of the rule would nail you.
Re: Nacra F16 [Re: Aido] #267966
12/23/13 06:56 AM
12/23/13 06:56 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Hinge? Straight in and out when out of the water being measured
Jeff Southall
Current boats
Nacra 5.8 1703 Cant have two Ram Raiders at the same time so not named yet
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Taipan 5.7 134
Arrow 1576
Re: Nacra F16 [Re: Aido] #267968
12/23/13 08:58 AM
12/23/13 08:58 AM
pgp Offline
pgp  Offline
No moving parts.
No appendages.
As such it's unclear to me if jibing boards are legal, you'd need a ruling.
Pete Pollard
Blade 702
Re: Nacra F16 [Re: Aido] #267975
12/23/13 12:56 PM
12/23/13 12:56 PM
Boards can not be more than 6deg from the vertical. AC style boards are clearly more than 6deg from the vertikal at sections.
Rudders are allowed horizontal appendages.
Jibing boards are allowed.
Re: Nacra F16 [Re: Rolf_Nilsen] #267978
12/23/13 03:05 PM
12/23/13 03:05 PM
M
mini Offline
mini  Offline
M
Nacra trying to drum up some sales.
They are already making curved boards, so why not just stick them on the 16 too - although technically it should not be called an F16 anymore.
Boards must be straight so J C or L foils are not class legal.
They can be canted but only a maximum of 6 degrees from vertical, and they can be asymetrical.
There is not any rule about how straight they have to be, so "jibbing" or as I have heard them refered to as "lazy boat builder boards" would be legal.
Re: Nacra F16 [Re: Aido] #267983
12/23/13 04:56 PM
12/23/13 04:56 PM
pgp Offline
pgp  Offline
Iirc there is a phrase in the rules related to boards that states "no moving parts".
I'll leave the interpretation to others.
Pete Pollard
Blade 702
Re: Nacra F16 [Re: pgp] #267985
12/23/13 06:00 PM
12/23/13 06:00 PM
waynemarlow Offline
waynemarlow  Offline
In a way I'm surprised Nacra haven't done this before, there are obvious benefits of hull lift for a smaller well powered up boat + some stability gains as well.
The one downside is that they will definately now ( or should ) be pinged in the handicap stakes for lifting boards unlike the present angled boards which seem to be classified as non lifting. I looked at modifying my boat with some first generation A Class curved boards I have but under SCHRS the penalty hit for curved boards was the equivalent of about 15 kilos of weight. I couldn't quite work out whether the older generation of board would give me in excess of 15 kgs of lift so the boards are still in my loft. Perhaps this winter Bitsa may get yet another bit of TLC.
Looking at the 2014 boat changes with smaller diameter mast,rudder stock changes, rudder with a new profile as well as a host of other things, my betting is that the boat must be getting quite close to class weight smile
Re: Nacra F16 [Re: Aido] #267986
12/24/13 03:38 AM
12/24/13 03:38 AM
felixshmak Offline
felixshmak  Offline
From what I have read from their web site. Curved board is not F16 class legal. So they made the board box able to accept both straight (ie. F16 class legal); and curved board (ie. more fun I believe).
I think it is a great idea, of course if they can make it foiling is even better.
Felix
NACRA F16
Re: Nacra F16 [Re: pgp] #268212
01/02/14 10:12 AM
01/02/14 10:12 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
The board has no moving parts.
Re: Nacra F16 [Re: Aido] #268237
01/03/14 02:20 PM
01/03/14 02:20 PM
But, if you had a section at the end of the board that pivoted more onto a horizontal plane on each tack, you'd be in violation.
1 registered members (Gary Fleming), 19 guests, and 100 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
brucat 10
JeffS 4
Gato 3
Beata 1
Topics22,313
Posts266,618
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
