Riveting into a carbon tube? #271280
04/09/14 09:38 PM
04/09/14 09:38 PM
Karl_Brogger Offline OP
Anything special I need to know? I broke my spin pole at the end of last year and I think I'm going to replace the aluminum tube with a carbon one. There's only a couple of fittings.
I'd assume a washer for a backer?
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271281
04/09/14 10:07 PM
04/09/14 10:07 PM
monel rivets, plenty of sealant, and a backer won't hurt.
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271282
04/09/14 10:18 PM
04/09/14 10:18 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=93799
there are special rivets for carbon fitting. AHPC/GD should be able to supply them
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Riveting into a carbon tube? [Re: Dazz] #271283
04/10/14 12:48 AM
04/10/14 12:48 AM
C
conrad dxb Offline
conrad dxb  Offline
C
We have not riveted our blocks to our carbon tubes we have lashed them on as this spreads the load all around the tube, as apposed to point load rivets, jib and spinnaker no problem , no holes.
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271299
04/10/14 03:40 PM
04/10/14 03:40 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Don't rivet - glue, strop or tie
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271308
04/10/14 06:26 PM
04/10/14 06:26 PM
That was kinda the gist of the thread that Dazz posted as well.
How about drilling a hole for the tack line to come out of the pole? Probably needs a grommet of some sort.
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271309
04/10/14 07:45 PM
04/10/14 07:45 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I've seen machined alum inserts that slip into the end of the pole, with a smoothly chamfered hole in the end for the tack line. They have a lip that's the same dia as the pole so they can be epoxied in without fasteners, and the load is transferred to the pole by the lip, not the glue.
Or I've also had alum caps constructed to distribute the loads, and the tack line could come out the end of this design as well.
22 spin 003.jpg (22 downloads)
ARC pole tip
Re: Riveting into a carbon tube? [Re: davefarmer] #271310
04/10/14 08:23 PM
04/10/14 08:23 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
SNU makes those.
Barefoot studios.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271314
04/11/14 05:09 AM
04/11/14 05:09 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
He needs a hole for the tack line to come out the side of the pole, not the end.
Re: Riveting into a carbon tube? [Re: Karl_Brogger] #271315
04/11/14 05:41 AM
04/11/14 05:41 AM
Karl,
With reference to your original post:-
Things to note- If stainless is in contact with carbon it will rust or corrode. So any stainless needs to be insulated with glass or resin or something else depending on your application. So bed all stainless fittings that you add in epoxy.
ALSO Carbon is not an especially great material to drill let alone rivet. So keep drilling and especially riveting to an absolute min and bed it all in a thickened epoxy mix.
Being the anal kind of person that I am, if I was making a pole that I was going to drill I'd make sure I included at least some glass in that area of the laminate if I was going to rivet I'd add kevlar just in that area.
As your not making the pole from scratch I'd follow Team VMG's advice. Paul summed it up as well as it could.
Good luck.
0 registered members (), 711 guests, and 203 spiders.
