Back ONLINE!
by Damon Linkous. 04/28/18 12:28 PM
CAT FIGHT VII
by TiberiusGV. 05/25/18 01:39 PM
Catamaran charter in BVI
by mickaelc. 05/25/18 11:44 AM
do you carry one of these?
by tback. 05/24/18 09:01 PM
Nacra17 rating for upcoming regatta
by Capt_Cardiac. 05/23/18 06:57 AM
Where did everyone go?
by NCSUtrey. 05/18/18 03:27 PM
Worrell 1000 Reunion Race
by Jake. 05/15/18 12:57 PM
Hobie FX One
by Damon Linkous. 05/12/18 04:15 PM
Help locating Center Boards
by IzzyHaber. 05/11/18 12:54 AM
Hull cover leakage
by samc99us. 05/10/18 06:30 AM
Rules Question - Downwind Finish
by Jake. 05/08/18 01:26 PM
Randy Smyth wins Multi champs in large Weta Fleet!
by Mark Schneider. 05/03/18 11:53 PM
Back ONLINE!
Making racks / wings #274206
07/26/14 03:50 PM
07/26/14 03:50 PM
Mike Fahle Offline OP
I know this has been discussed before but I cannot find any useful info using the search function so I need a little assistance. I am happy to do my own design work, I'm just looking for these things: Specifically I would like to know the measurements that a Hobie 18 magnum wing/rack extends from the side of the boat AND above the deck (I had one for many years so I am familiar with how it sails), how wide the actual sitting portion is, and also how much one weighs for reference. Last, does anyone know a good website to determine deflection for aluminum tubing of various dimensions? Thanks!
Re: Making racks / wings [Re: Mike Fahle] #274212
07/26/14 09:23 PM
07/26/14 09:23 PM
Lee Wicklund, paging Lee Wicklund.
Re: Making racks / wings [Re: Mike Fahle] #274213
07/26/14 09:46 PM
07/26/14 09:46 PM
K
Kilty
Kilty
K
This might help a little, although it doesn't address the Magnum wings specifically....
http://static.hobiecat.com/2010_archive/media/pdf/euro_wings.pdf
Re: Making racks / wings [Re: Mike Fahle] #274240
07/28/14 09:57 AM
07/28/14 09:57 AM
catman Offline
catman  Offline
I know someone who has Magnum wings. I'll talk to him today and see if he can measure for you.
I had magnums on my 18 and I believe both wings with the mounting hardware and vinyl covers installed were 36-38 lbs.
Re: Making racks / wings [Re: Mike Fahle] #274247
07/28/14 02:28 PM
07/28/14 02:28 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
What boat are they for?
Re: Making racks / wings [Re: Karl_Brogger] #274255
07/28/14 09:29 PM
07/28/14 09:29 PM
TeamChums Offline
TeamChums  Offline
I went with 16" higher than the deck, (inner bar location), 12" out from the side. the outer bar is 16" apart from the inner bar and extends about 8" past the sterns.
Lee
Sail fast or get the hell out of the way.
Re: Making racks / wings [Re: Mike Fahle] #274275
07/29/14 11:17 AM
07/29/14 11:17 AM
catman Offline
catman  Offline
He called me back today, Should know later this afternoon.
Re: Making racks / wings [Re: Mike Fahle] #274276
07/29/14 11:31 AM
07/29/14 11:31 AM
catman Offline
catman  Offline
He sent me pic's with a tape measure showing the dimensions. Should be enough to get the info. Check PM.
Re: Making racks / wings [Re: Mike Fahle] #274335
07/31/14 10:24 AM
07/31/14 10:24 AM
Thanks, Catman, I sent my e-mail address. I have a pretty good library of wings/racks of all shapes and sizes but getting the tube dimensions is not easy. I have a good local source for tubing once I know what to order. I also found a good source of prebent tube sections with the intention of putting together wings without welding. That dictates the tube sizes so it will not be ideal but should be close. I should be able to report on the results of that experiment in a week or two.
Re: Making racks / wings [Re: Mike Fahle] #274336
07/31/14 10:33 AM
07/31/14 10:33 AM
catman Offline
catman  Offline
Sent to your email.
I have a friend who used to work at JSI building spars and he built a custom pair for his M6.0. I can ask him what wall thickness he used or for that matter the exact tube he used if you like.
Re: Making racks / wings [Re: Mike Fahle] #274342
07/31/14 01:43 PM
07/31/14 01:43 PM
That would be great - just the kind of info I am looking for. I think that Hobie used 1 7/8" OD with .83 thickness tubing for the original magnum wings but it is hard to find that documented anywhere.
Re: Making racks / wings [Re: Mike Fahle] #274387
08/04/14 02:42 PM
08/04/14 02:42 PM
O
orphan Offline
orphan  Offline
O
Mike,
I took a set of H18SX wings and fit them to my M6.0. Dilled out the rivets for the rear crossbar support and reriveted correct distance between front and rear cross bar. Bent and cut the rear support leg and cutoff and rewelded the front support leg. Much easier than building an entire set from scratch. [img]http://thebeachcats.com/pictures?g2_itemId=109253[/img]
Re: Making racks / wings [Re: orphan] #274395
08/04/14 10:38 PM
08/04/14 10:38 PM
TeamChums Offline
TeamChums  Offline
Lee
Re: Making racks / wings [Re: TeamChums] #274398
08/05/14 07:09 AM
08/05/14 07:09 AM
Very cool...I guess with the Nacra 20 class not really being a class anymore, that kind of mod really makes sense. Did you do the GT300 with the wings?
From a design standpoint, having the wings be self-supporting does make things simpler to operate but it changes the rigging loads (the shroud now supports the extra leverage instead of the trapeze wires) and adds slightly more weight (very slight). I'm sure that there is plenty of extra load carrying ability in the shrouds for that - but using the trap wires to support the wing instead of bracing it back to the beam will stay closer to the original loading configuration. On the other hand, you would have to rig up some other trapeze configuration in order to trap off the wing...and a wing that doesn't have the bracing to keep it in place, might fold up on you...
huh. So, yeah, nevermind. Looks great.
Re: Making racks / wings [Re: Jake] #274411
08/05/14 09:49 PM
08/05/14 09:49 PM
TeamChums Offline
TeamChums  Offline
There are braces that go from the end caps to under the inner most tubes. I'll post pics of them when I get it rigged up this weekend. We will be trapping off of them and rigging up a chicken line system for an open ocean race in Ventura on the 16th. We'll run them next year in the GT. I'll be making an adjustable tension shroud/back stay from Vectran/Amsteel on each side that goes to each wing. You can see the overbuilt tab on the cross beam cap (little triangle) for the under support (not shown) which is made out of 1" tubing (later to be replaced with Carbon tubes as well).
Thanks Jake. It's been fun designing them and finally making them. Complicated to explain how the outer bar will be replaced with Carbon but I'll take lots of pictures.
https://fbcdn-sphotos-f-a.akamaihd....3121200_234f3dfbb55aa08a3bec68d02ce37d42
https://scontent-b-lax.xx.fbcdn.net...03180013199664_5573179264306061282_n.jpg
Lee
Re: Making racks / wings [Re: TeamChums] #274418
08/06/14 09:40 AM
08/06/14 09:40 AM
I see you didn't forget the cup holders! grin
Did you beef up those rear beam bolts from inside the hull? You're asking a little more out of them with the extra righting leverage and they have proven to not quite be up to the task in the original configuration.
How much weight do you think you will save with the carbon vs. aluminum?
Re: Making racks / wings [Re: Jake] #274425
08/06/14 07:17 PM
08/06/14 07:17 PM
TeamChums Offline
TeamChums  Offline
2 years ago I had the boat completely sanded down and painted instead of gelcoat. At that time I had the place lay up the beam sockets with carbon to beef them up. Not sure what weight savings yet but I will when they're done. I guess I'll find out more from whoever I order it from.
Those aren't cup holders. They're to reduce windage.... wink
Lee
Re: Making racks / wings [Re: TeamChums] #274428
08/06/14 08:57 PM
08/06/14 08:57 PM
If you've got any pictures showing the detail of the bracket that attaches to the beam, I would really like to see it. I've been thinking about doing something like this to the F18.
Re: Making racks / wings [Re: Jake] #274446
08/07/14 09:25 AM
08/07/14 09:25 AM
so what's the max beam with the wings?
Re: Making racks / wings [Re: Mike Fahle] #281777
02/03/16 01:57 PM
02/03/16 01:57 PM
O
oldgeezer Offline
oldgeezer  Offline
O
Any suggestions for wings on an FX one? I desperately need wings so I can stay out sailing for more than hour. It has suggested that I give sailing but it is one of the few things I can still manage to do (old age has caught up to me - 85 next month) Thanks from an oldgeezer
0 registered members (), 11 guests, and 155 spiders.
mickaelc, NC_P19MX, ravenousailor, Jimbojas, Zaldivar
7782 Registered Users
Jake 7
MikeB 5
srm 3
Topics22,301
Posts266,563
Members7,782
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
