| Weather App #282301 03/29/16 05:55 AM 03/29/16 05:55 AM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek OP
Posts: 139 Hernando, Florida | I've been using weather underground for weather reports. Unfortunately they can't predict it if they were standing in it.
Anyone out there have better suggestions?
Thanks
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
| | | Re: Weather App
[Re: Mlcreek]
#282302 03/29/16 07:41 AM 03/29/16 07:41 AM |
Posts: 3,969 | Here's my rule of thumb:
TV weather: Should I wear more layers?
Wunderground, The Weather Channel sites/apps: What's on the RADAR?
For wind predictions, start with an app such as WindAlert (they've acquired a bunch of others). The quality of the forecasts from these apps varies by location, however, so check around with locals or just monitor a few for a while.
For the best forecasts, there are subscription services. These are definitely location sensitive, especially for a place with complex features (land/water/prevailing flows).
Most times, a combination of the first three is sufficient. When running important regattas in Newport, decisions on where to race (ocean vs bay) or whether (and how long) to postpone ashore can make the paid services invaluable.
Hope this helps.
Mike | | | Re: Weather App
[Re: Mlcreek]
#282303 03/29/16 07:46 AM 03/29/16 07:46 AM |
Posts: 3,906 Clermont, FL, USA | SailFlow, there is a free smart phone app.
| | | Re: Weather App
[Re: Mlcreek]
#282312 03/29/16 02:06 PM 03/29/16 02:06 PM |
Posts: 5,590 Naples, FL | I have windfinder on my phone which is reasonably accurate (although they are generous on the windspeed forecast... usually about 5 mph faster than actual). They're based on local airport WX stations so they can give you an idea of what you'll see around that area.
| | | Re: Weather App
[Re: cyberspeed]
#282320 03/30/16 05:31 AM 03/30/16 05:31 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I used Sailflow a couple of years ago, until they improved it. Then it was worthless. So, did they improve it.., really, or did they unimprove it?
| | | Re: Weather App
[Re: Mlcreek]
#282321 03/30/16 07:27 AM 03/30/16 07:27 AM |
Posts: 3,969 | Several mentions in this thread of WeatherFlow products (WindAlert, SailFlow), another local favorite is iWindsurf. As I mentioned above, they are related, and definitely have the similar look/feel, if not identical forecasts. More info: http://www.weatherflow.com/consumer-products/Makes me wonder how independent the others are? In any case, no forecast or tool is 100% correct all of the time, and sometimes they are WAY off. The very best (usually paid) include a confidence level, and other things that might happen on a difficult day. Mike | | | Re: Weather App
[Re: RickWhite]
#282324 03/30/16 08:59 AM 03/30/16 08:59 AM |
Posts: 3,906 Clermont, FL, USA | I used Sailflow a couple of years ago, until they improved it. Then it was worthless. So, did they improve it.., really, or did they unimprove it? http://www.sailflow.com/ if you like it use it if you don't move on, there are a lot of options. I also use the NOAA site, http://www.srh.noaa.gov/mlb/.What do you use Rick?
1 registered members (TimTT),
600
guests, and 94
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
