Back ONLINE!
by Damon Linkous. 04/28/18 12:28 PM
Nacra17 rating for upcoming regatta
by Capt_Cardiac. 05/23/18 06:57 AM
Where did everyone go?
by NCSUtrey. 05/18/18 03:27 PM
Worrell 1000 Reunion Race
by Jake. 05/15/18 12:57 PM
Hobie FX One
by Damon Linkous. 05/12/18 04:15 PM
Help locating Center Boards
by IzzyHaber. 05/11/18 12:54 AM
Hull cover leakage
by samc99us. 05/10/18 06:30 AM
Rules Question - Downwind Finish
by Jake. 05/08/18 01:26 PM
Randy Smyth wins Multi champs in large Weta Fleet!
by Mark Schneider. 05/03/18 11:53 PM
Back ONLINE!
Page 19 of 19 1 2 17 18 19
Re: F85SR Concept Boat [Re: phill] #285816
02/15/17 10:19 AM
02/15/17 10:19 AM
can you just strap the ginny pole to the boom while storing/sailing? Do the "ears" obstruct free movement of the boom?
Re: F85SR Concept Boat [Re: phill] #285925
02/18/17 10:56 AM
02/18/17 10:56 AM
Colorado
F-25c Offline
F-25c  Offline
Colorado
Hey Phil, I'm researching DIY CNC router tables. Can you make any recommendations? The purpose of the table would be for my F-85 build.
Re: F85SR Concept Boat [Re: phill] #285988
02/20/17 02:32 PM
02/20/17 02:32 PM
Central Coast NSW Australia
phill Offline OP
phill  Offline OP
Your best bet would be to talk to Mark. He built his own CNC machine and did all my CNC work.I'll send you a message with his email address.
Re: F85SR Concept Boat [Re: phill] #286004
02/21/17 01:44 AM
02/21/17 01:44 AM
phill Offline OP
phill  Offline OP
I have sent you a message with Mark's email address.
Re: F85SR Concept Boat [Re: phill] #286020
02/21/17 01:21 PM
02/21/17 01:21 PM
Colorado
F-25c Offline
F-25c  Offline
Colorado
Thanks. I got the PM. A question on your hull paint. Did you end up covering the 2 pack paint with an epoxy barrier coat below the water line? I'm trying to determine if I will apply barrier coat on top of my paint. My boat is trailer sailed, but may end up in the water for up to a week at a time.
Re: F85SR Concept Boat [Re: phill] #286049
02/22/17 04:33 AM
02/22/17 04:33 AM
phill Offline OP
phill  Offline OP
No I didn't. A week in the water isn't a problem if you give the bottom a scrub before you pull it out of the water. Not much boat in the water so it is pretty easy.
Re: F85SR Concept Boat [Re: phill] #286056
02/22/17 09:02 AM
02/22/17 09:02 AM
Colorado
F-25c Offline
F-25c  Offline
Colorado
That's music to my ears. I determined I'd be OK, but there are a lot of "experts" on the forums that spoke otherwise.
Re: F85SR Concept Boat [Re: F-25c] #286067
02/22/17 11:09 AM
02/22/17 11:09 AM
Phill,
As I understand from the main forum, this catsailor site/board may soon close or become defunct as Rick's family has very little interest in continuing it.
Is all of this wonderful build information available elsewhere in case that happens? Your work on the boat (and documentation here) is a veritable gold mine (and eye candy) of information
Re: F85SR Concept Boat [Re: phill] #286077
02/22/17 04:13 PM
02/22/17 04:13 PM
phill Offline OP
phill  Offline OP
Jay,
I have a backup of everything that I have posted including the missing photos that were lost when this site's photo albumn stopped working. I also have many hundreds of other photos.
If this site goes down I will most likely edit what I have adding in the missing photos plus any others that I think may help and put it all somewhere else.
Re: F85SR Concept Boat [Re: phill] #286190
02/25/17 11:55 PM
02/25/17 11:55 PM
phill Offline OP
phill  Offline OP
You can save up to 7kg by using dyneema netting as opposed to vinyl coated fablock type of netting. You can also save a lot of money because it is very easy to finish the edges without sewing. I finished the edges of my nets and fitted them for a cost of around $100 ea. I got a really good deal on the dyneema netting from ebay. For anyone looking at replacing their nets it could be worth a check of ebay first. Look for Golf practice nets. Mine are dyneema SK75.
Re: F85SR Concept Boat [Re: phill] #286213
02/26/17 03:01 PM
02/26/17 03:01 PM
phill Offline OP
phill  Offline OP
Here is a pic of the net. It still needs to be taken off so the wing net rail can be painted.
When I do that I'll redo the edges and trim the excess netting now it has stopped creeping.
Mad Hatters Nets sm.jpg (323 downloads)
Re: F85SR Concept Boat [Re: phill] #287944
09/30/17 06:19 AM
09/30/17 06:19 AM
phill Offline OP
phill  Offline OP
[quote][/quote]
Mad Hatters Nets sm.jpg (56 downloads)
Re: F85SR Concept Boat [Re: phill] #288030
11/02/17 08:43 PM
11/02/17 08:43 PM
phill Offline OP
phill  Offline OP
We sailed the Mad Hatter from Lake Macquarie to Gosford and back last weekend.
I finally had a chance to try out the Go Pro that the kids gave me.
The video goes for 5 mins. Take note it is 5mins you won't get back if you don't like it.
https://www.youtube.com/watch?v=8dUDIktAsCY&feature=youtu.be
Re: F85SR Concept Boat [Re: phill] #288031
11/03/17 01:14 PM
11/03/17 01:14 PM
the Netherlands
nico peursum Offline
the Netherlands
Nice video Phill. Thanks for sharing
Re: F85SR Concept Boat [Re: phill] #288179
01/22/18 08:54 AM
01/22/18 08:54 AM
Wilhelmshaven, Niedersachsen, ...
L
luckystrike118 Offline
L
Hi Phil,
can you ,eave a little information about your nets? How thick (mm) are your strings and how wide are your mashes?
Thanks, Michel
hullaballo
Re: F85SR Concept Boat [Re: phill] #288183
01/22/18 10:47 PM
01/22/18 10:47 PM
phill Offline OP
phill  Offline OP
Michel,
The mesh size is 22mm and the woven thread width is either 3mm or 3.5mm.
The edging is just the mesh wrapped around 8mm double braid polyester rope with a 3mm cord zig zagged through the squares in 3 rows.
This is then lashed on with 6mm double braid.
Initially I was concerned about the mesh size as I wanted it smaller but having used it I think it is perfect. I find it reasonably comfortable and even my better half says it is comfortable. The added bonus is it is just the right size to get a good hand hold when needed as ones fingers can fit through the mesh .
I hope this helps.
Re: F85SR Concept Boat [Re: phill] #288269
02/02/18 06:34 AM
02/02/18 06:34 AM
phill Offline OP
phill  Offline OP
I've posted another video on youtube of last Sundays race.
https://youtu.be/pEiLQ4z8e8A
1 registered members (Isotope235), 35 guests, and 166 spiders.
mickaelc, NC_P19MX, ravenousailor, Jimbojas, Zaldivar
7782 Registered Users
Jake 7
MikeB 5
srm 3
Topics22,298
Posts266,558
Members7,780
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
