To Epoxy & an '85 with a H on the Pilon #32188
04/06/04 10:43 PM
04/06/04 10:43 PM
DanWiz Offline OP
DanWiz  Offline OP
Based on the overwhelming response, it looks like I will epxoy the frame. The hulls do have the red seam. The pilons have an "H" etched into them. From reading, it sounds like weight may have been added due to the reduced weight of the hulls with the red epoxy. Has anyone had experience removing this weight?
Never did hear any responses about experiences of getting the parts apart for replacement. Any experience?
Dan
Re: To Epoxy & an '85 with a H on the Pilon [Re: DanWiz] #32189
04/06/04 11:09 PM
04/06/04 11:09 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Dan,
I've taken a couple Hobie's apart and they didn't go too bad. Remove the tramp and pylon bolts and use a rubber mallet, or a block of wood with a hammer to remove the corner castings. Often times they are stubborn to remove unless you have the hull in perfect alignment. If the casting is binding when you try to remove it, it's going to cause you fits. Just wiggle the hull up and down / side to side until you find the loosest position. Hope that makes sense.
Jack Hoying
Fort Loramie, Ohio
Re: To Epoxy & an '85 with a H on the Pilon [Re: jmhoying] #32190
04/07/04 02:37 PM
04/07/04 02:37 PM
Dan,
I had an '84 that had several pounds of lead shot in the rear pylons underneath a plug of urethane foam. You need to take the standard foam plug out of the top of the pylon (it's not glued in, so it just pulls out). Look down the pylon - ordinarily you can see right to the bottom of the pylon. If you can't, and you see the brownish foam - use a long tool to chip away at it until you get to the lead. Be careful not to damage the "shoe" that the pylon rests in that connects it to the sides of the hulls.
Re: To Epoxy & an '85 with a H on the Pilon [Re: mbounds] #32191
01/06/05 04:27 PM
01/06/05 04:27 PM
Central Texas
yoh Offline
yoh  Offline
Central Texas
I have the frame apart on my '85 Hobie - mostly to re-rivet the x-bars, to shim the pylons and to install the new tramp. My foam plugs looked kind of deteriorated and I decided to remove them. On my Hobie they seemed like they were siliconed in place - but not very securely. I found water (a few ounces) in each pylon. No loose lead in my pylons. The hulls were drained many weeks ago when the boat was used the last time. It seems like the opening in the pylon that allows the hulls to ventilate is drilled higher than the "shoe" that holds the bottom of the pylon so that water cannot drain back into the hull.
I would like to replace the pylon plugs - it looks like they are made from closed cell polyethylene (looks like Ethafoam) - IIRC other sailor used swimming aids (like aqua noodles) to plug the pylons.
Any other ideas that might work???
Patrick, Hobie 16 '85
Re: To Epoxy & an '85 with a H on the Pilon [Re: yoh] #32192
01/08/05 11:39 AM
01/08/05 11:39 AM
West Texas
JaimeZX Offline
JaimeZX  Offline
West Texas
I used a piece from an aqua noodle (and lots of silicone) to re-plug the top of my mast, so I guess it would work.
Warm regards, Jim
0 registered members (), 195 guests, and 35 spiders.
