Nacra 5.2 line lengths #35263
07/08/04 01:57 PM
07/08/04 01:57 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
I have this listing of running rigging lengths, many of which are contrary to some of my existing lines (i.e. mainsheet).
Any opinions and/or additions out there?
Main Halyard - 28' 3/16"
Jib Halyard - 23' 3/16"
Jib Sheet - 40' 5/16" continuous
Main Sheet/Traveler - 42' 3/8" continuous
Mast Rotator - 3' 1/4"
Outhaul - 10' 1/4"
Downhaul - 8' 1/4"
Thanks
Tim S. Urfer 1984 Nacra 5.2
Re: Nacra 5.2 line lengths [Re: TSurfer] #35264
07/11/04 11:08 PM
07/11/04 11:08 PM
Andrew Offline
Andrew  Offline
Double the main halyard length; that sounds about like the mast height on a 5.2, you need twice the mast length "plus a little" to actually hoist the sail. Same for the jib halyard. Can't tell for the mainsheet; the purchase of your block system makes a difference.
good luck.
Re: Nacra 5.2 line lengths [Re: Andrew] #35265
07/12/04 10:42 AM
07/12/04 10:42 AM
Maryland
Kris Hathaway Offline
Maryland
The main halyard length may seem short because it is half wire, half line. Perhaps the measurement is only for the line section.
Kris Hathaway
Re: Nacra 5.2 line lengths [Re: Kris Hathaway] #35266
07/12/04 12:52 PM
07/12/04 12:52 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
Yeah, I should have been clearer on my original post.
I meant just the line portion.
Also the smaller measurements i.e. 3/8, 5/16 are for the line diameter.
Re: Nacra 5.2 line lengths [Re: TSurfer] #35267
07/12/04 02:06 PM
07/12/04 02:06 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
If youre going to play the downhaul from the wire(which you should) your downhaul needs to be much longer. Id say 20ft, maybe longer.
David
Re: Nacra 5.2 line lengths [Re: dave mosley] #35268
07/12/04 02:47 PM
07/12/04 02:47 PM
dickcnacra52 Offline
Gotta ask all you experienced guys a question if I could. The last answer indicates adjusting the downhaul while on the wire. I'm totally new to a cat, and will be single handing my 5.2 - I just don't seem to have enough hands as I can tell. I've got to handle the tiller, and the mainsheet, and trap out and now also do the down haul? Our club has the "crushed can" award for doing the stupidest thing during the year. Any help in telling me how you would handle all those items as a "newbie" single hander so that I don't win the dreaded award would be appreciated!
Dick
Re: Nacra 5.2 line lengths [Re: dave mosley] #35269
07/12/04 10:50 PM
07/12/04 10:50 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
David,
Can you describe how that's rigged? Cleat and block placement etc...
Thanks
Re: Nacra 5.2 line lengths [Re: dickcnacra52] #35270
07/13/04 07:20 AM
07/13/04 07:20 AM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
Attach the end of your downhaul line to your trapeze wire. When you need the line, it is there with you. Hold the tiller and mainsheet (traveller line is tied to end of mainsheet), one in each hand. When you want to adjust downhaul, hold mainsheet with finger from tiller hand and make the adjustment. Then drop the downhaul and pick up the mainsheet again.
Les Gallagher
0 registered members (), 309 guests, and 40 spiders.
