| Nacra 5.2 line lengths #35263 07/08/04 01:57 PM 07/08/04 01:57 PM |
Posts: 69 San Francisco | I have this listing of running rigging lengths, many of which are contrary to some of my existing lines (i.e. mainsheet).
Any opinions and/or additions out there?
Main Halyard - 28' 3/16" Jib Halyard - 23' 3/16" Jib Sheet - 40' 5/16" continuous Main Sheet/Traveler - 42' 3/8" continuous Mast Rotator - 3' 1/4" Outhaul - 10' 1/4" Downhaul - 8' 1/4"
Thanks
Tim S. Urfer
1984 Nacra 5.2
| | | Re: Nacra 5.2 line lengths
[Re: TSurfer]
#35264 07/11/04 11:08 PM 07/11/04 11:08 PM |
Posts: 364 | Double the main halyard length; that sounds about like the mast height on a 5.2, you need twice the mast length "plus a little" to actually hoist the sail. Same for the jib halyard. Can't tell for the mainsheet; the purchase of your block system makes a difference. good luck.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Andrew]
#35265 07/12/04 10:42 AM 07/12/04 10:42 AM |
Posts: 606 Maryland | The main halyard length may seem short because it is half wire, half line. Perhaps the measurement is only for the line section.
Kris Hathaway | | | Re: Nacra 5.2 line lengths
[Re: Kris Hathaway]
#35266 07/12/04 12:52 PM 07/12/04 12:52 PM |
Posts: 69 San Francisco | Yeah, I should have been clearer on my original post. I meant just the line portion.
Also the smaller measurements i.e. 3/8, 5/16 are for the line diameter.
Tim S. Urfer
1984 Nacra 5.2
[Re: TSurfer]
#35267 07/12/04 02:06 PM 07/12/04 02:06 PM |
Posts: 1,253 Columbia South Carolina, USA | If youre going to play the downhaul from the wire(which you should) your downhaul needs to be much longer. Id say 20ft, maybe longer. David
[Re: dave mosley]
#35269 07/12/04 10:50 PM 07/12/04 10:50 PM |
Posts: 69 San Francisco | David, Can you describe how that's rigged? Cleat and block placement etc...
Thanks
Tim S. Urfer
1984 Nacra 5.2
[Re: dickcnacra52]
#35270 07/13/04 07:20 AM 07/13/04 07:20 AM |
Posts: 371 Michigan, USA | Attach the end of your downhaul line to your trapeze wire. When you need the line, it is there with you. Hold the tiller and mainsheet (traveller line is tied to end of mainsheet), one in each hand. When you want to adjust downhaul, hold mainsheet with finger from tiller hand and make the adjustment. Then drop the downhaul and pick up the mainsheet again.
Les Gallagher
3,236
guests, and 277
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
