Ben
Good to hear you finally got a 14! I told you when you got one, I would pester you to show up to a few races!!
If you have the dolphin striker, the only thing you need to do is add the trapeze wires. I suggest attaching them to the large shackle at the mast tang with individual smaller shackles, or to use a really big shackle and put everything on it. This keeps all the wires frim binding on each other.
This is a link for line lengths on a 14:
http://www.nahca.org/hobies/hobie14_linelengths.htmIf you want to convert it to a Turbo, I still have a new jib I got from a bulk order deal. I also can help out in the Maxi conversion--wether you need parts or advice..
Camp Hatteras is coming up at the end of August and there should be 3 14 Maxis!!!
