| Re: Hobie 16 Trapeze & Righting System Questions
[Re: NoBeginner]
#36981 08/18/04 03:06 PM 08/18/04 03:06 PM |
Posts: 805 Gainesville, FL 32607 USA | Hmmm...solo...150 pounds...54 degree water in Lake Michigan below 6 inches... old Hobie 16 with (old?) shrouds.... Please read the thread on Hobie Tiger righting and righting systems including PowerRighter. Then buy or build a system and learn how to use it in WARM WATER. A Hawaiian style righting system won't help a 150 pound solo sailor enough. I ran mine outside the pylons to use it 99.9% of the time as a chicken line. New wires and Mast sealing are absolutely critical.
Otherwise you are referred to a thread on this forum several years ago about a similar H16 sailor who loved going solo offshore Cape Cod by himself. Sadly, he did not pay attention to anyone's posted suggestions about righting gear, wet suit, weather, time of day, etc. but was happy jumping waves without all that attention to detail. After a few weeks, he qualified for a Darwin Award, and is no longer with us.
[Re: dacarls]
#36982 08/18/04 03:19 PM 08/18/04 03:19 PM |
Posts: 1,884 Detroit, MI | The Hobie 18 and Hobie 16 have fundamentally different shock cord arrangements for the trapeze. The 16's shock cords run underneath the trampoline from one trapeze to the other, not under the deck lip like the 18. No trapeze return system is designed to prevent you from taking a trip around the forestay in a pitchpole. That's what footstraps are for (besides breaking ankles). You have to hope there is enough stretch in the return system that nothing breaks  . Go to The Hobie 16 Worlds Photos and look at some of the beach pictures. You can clearly see what we were using on our trapeze set ups. The righting lines we used were simple lengths of line, tied to the dolphin striker and stuffed into the pouch on the tramp. When you flip, you pull out the line, toss it over the upper hull, right the boat, then stuff it back in. Simple, cheap, and very effective. | | | Re: Hobie 16 Trapeze & Righting System Questions
[Re: mbounds]
#36983 08/18/04 04:12 PM 08/18/04 04:12 PM |
Posts: 1,253 Columbia South Carolina, USA | Just a couple of hints.
Never attach port and starboard bungees of your trapeze system togther. If you do go around the forestay and break the port one, then your starboard side is broken too. Run them seperately, all of them. Make them extra long, using blocks for them to run thru under the tramp. The more bungee, the better it will take the "trip around".
Get the power righting pole, it may save your life. Carry a sharp knife. Never go out without someone "looking out for your return".
David Mosley F18 on the way(I will be glad when its here!)
[Re: dave mosley]
#36984 08/18/04 05:34 PM 08/18/04 05:34 PM |
Posts: 2,718 St Petersburg FL | Never attach port and starboard bungees of your trapeze system togther. If you do go around the forestay and break the port one, then your starboard side is broken too. Run them seperately, all of them. Make them extra long, using blocks for them to run thru under the tramp. The more bungee, the better it will take the "trip around".
Would this setup be class legal? Can you provide a diagram of somewhat to have a bigger and better picture. I love how this setup sounds. It would be a really nice setup.
[Re: NoBeginner]
#36985 08/18/04 10:08 PM 08/18/04 10:08 PM |
Joined: Mar 2003 Posts: 736 Westport, Ma. U.S.A. Brian_Mc
Posts: 736 Westport, Ma. U.S.A. | The righting system and trap returns shouldn't conflict. Most of the H16 sailors I know have both. Matt's suggestion for a righting line is good, but the Hawaiian is great for crew as a chicken wire, or if you're lucky enough to get a Soloright, they are great for the solo sailor when righting the cat. To get the Hawaiian line while standing on the hull in the water, reach up and grab the closest end, then pull out all the slack, and while holding on with one hand, so the bungee doesn't take it up again, throw it over the top of the hull and grab it on the other side. Then you can pull it down and use it as you wish. Good luck! | | |
428
guests, and 42
