New England 100 2018
by brucat. 07/22/18 06:03 AM
do you carry one of these?
by brucat. 07/21/18 08:59 PM
F16 Effect Crew Weight Solo and 2 Up
by samc99us. 07/20/18 01:12 PM
CL258 and CL259 Clamcleats for Trap Harness
by samc99us. 07/20/18 01:11 PM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
harken cleat #37963
09/12/04 07:12 PM
09/12/04 07:12 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
One jaw, on the cleat on my harken low profile blocks is not workling.Seems like the spring is gone.Is there a fix?
Re: harken cleat [Re: mmadge] #37964
09/12/04 09:09 PM
09/12/04 09:09 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
It's possible tht the spring is just our of place. Remove the screw and pull the cleat apart and see that the spring is in the proper notch. There are some loose bearings in the cleat, so take it apart on a towel.
Good luck,
Jack
Re: harken cleat [Re: mmadge] #37965
09/16/04 10:12 PM
09/16/04 10:12 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
Harken (HSB56) and West Marine (202523) both sell the replacement springs. If you've busted a spring, chances are your cleat's pretty old...I actually managed to wear one out. Take a good look at the teeth. If they're really worn, it may just be time for a replacement...also available from Harken (150) or West (114652).
Jerome Vaughan
Hobie 16 "RATTLE 'N HUM"
Jerome Vaughan
Hobie 16
Re: harken cleat [Re: rattlenhum] #37966
09/18/04 08:17 AM
09/18/04 08:17 AM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Opened it up ,spring had come disconnected and had a kink in it .Tried to fix it and it broke.I ordered a new spring.Blocks are only two summers old so jaws are still in good shape
1 registered members (Isotope235), 27 guests, and 234 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
brucat 9
JeffS 4
Gato 3
Beata 1
Topics22,313
Posts266,617
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
