boom caps #38338
09/21/04 09:13 PM
09/21/04 09:13 PM
Jon8791 Offline OP
Jon8791  Offline OP
Can anyone provide some tips on removing boom caps. I have drilled out the rivets with a 3/16th bit, but the cap with the gooseneck just won't budge.
Thanks
Re: boom caps [Re: Jon8791] #38339
09/22/04 06:08 AM
09/22/04 06:08 AM
try some wd40 to clean / lube all the crap and salt etc tha twill be in there. Leave for 10 minutes and try again.
If that does not work, get some hot water from a tap and pour over the OUTSIDE of the boom (this should cause the Al. to expand quicker then the stopper and thus make it easier.
Re: boom caps [Re: scooby_simon] #38340
09/22/04 11:37 AM
09/22/04 11:37 AM
California
mmiller Offline
mmiller  Offline
California
Beat it out. Get a stout blade screw driver. Fit it into the boom's slot, catch an edge of the casting and wack the screw driver handle with a mallet. May have to try a few times around the casting. These usually fuse it pretty good with salt and corrosion.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: boom caps - on to next problem [Re: mmiller] #38341
09/22/04 11:34 PM
09/22/04 11:34 PM
Jon8791 Offline OP
Jon8791  Offline OP
Great, boom caps are off after a lot of pounding.
Any advice on removing the fairlead from the rear cross bar? I am restoring an old 16 and removing all the hardware to paint. A number of the screws that hold the fairlead onto the cross bar are rusted. Can't tell what I need to do to get it off.
Re: boom caps - on to next problem [Re: Jon8791] #38342
09/23/04 04:57 PM
09/23/04 04:57 PM
California
mmiller Offline
mmiller  Offline
California
Fairlead?
The swivel cleat mounted in the middle? or the eye on the back side?
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: boom caps - on to next problem [Re: mmiller] #38343
09/23/04 09:54 PM
09/23/04 09:54 PM
Jon8791 Offline OP
Jon8791  Offline OP
swivel cleat. The screws are pretty rusted. I can't tell what is holding it to the rear cross bar and what I should drill out.
Re: boom caps - on to next problem [Re: Jon8791] #38344
09/24/04 08:03 AM
09/24/04 08:03 AM
West Texas
JaimeZX Offline
JaimeZX  Offline
West Texas
There are four screws in the plastic base to the swivel cleat. Three are sheet metal screws and one is a machine screw. The three sheet metal screws are the ones holding the base to the crossbar. (The three aft-most screws.)
Warm regards, Jim
0 registered members (), 460 guests, and 36 spiders.
