| Re: ...brink
[Re: pkilkenny]
#38424 09/27/04 07:34 PM 09/27/04 07:34 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Hey Paul, that picture is SICK. By the seastate it looks like there's no more than 4-5 knots of wind yet you're on the wire. What point of sail are you one--looks like little mast rotation.
I still need to digitize my Huntington video--similar conditions and you'll see that I'm doing everything wrong. I guess I'm more of a luffer than choker. And I'm also a tack-blower and a capsizer. I'll move my blocks and give choking a try, though. The problem I have with choking, philosophically, is that it stalls the flow of air on the spinnaker more than a mild luff. Maybe I should reread Bethwaite.
Also, being at least 40lbs heavier than you may affect what works. I know I just can't trap upwind until it is at least 8 knots steadily; otherwise I'm better off hiking in and out. But maybe an adjustable height trap is that answer for me.
| | | Re: ...brink
[Re: pkilkenny]
#38425 09/29/04 08:21 AM 09/29/04 08:21 AM | Anonymous
| Anonymous
Unregistered | Hi pkikenny, Thanks for your thought provoking posts. I certainly agree with some of what you say and have already addressed trap height ajustment and sheeting the spinnaker inboard from the sidestay in my rigging of Altered. Although your pictures could prompt some alterations before launch. I must urge some caution though, in the sheeting of the spinnaker as individual designs can have a bearing on this. Eg. Mosquito at 7'2" wide sidestay sheeting, has a narrower slot than Altered at 8'2" wide sidestay sheeting. Also pole length/foot length of spin. effect the overlap or not of the spin. with the mainsail which effects the size of the slot. I must say Iam a luffer rather than a choker. Certainly you will get more power to get you on trap. flying a hull etc. by sheeting closer/tighter, but speed can only come from a clean exhaust so I am back to easing the spin. luff until it curls as soon as the hull is out and drag has reduced, reducing the need for power. Remember the F16 motto the only real need. "IS THE NEED FOR SPEED". Yeah and being a bit crazy doesn't hurt either, especialy for us one up sailors. Regards Gary. | | | Re: ...brink
[Re: vicatman]
#38429 10/20/04 04:27 AM 10/20/04 04:27 AM | Anonymous
| Anonymous
Unregistered | Hi Vicatman, have a look at the Victorian Mosquito website, Tim has done a heap of work on this, lots of pictures and hints and most of it of one up boats. http://home.vicnet.net.au/~mosquito/Regards Gary. | | |
428
guests, and 42
