Aussie Nacra Nationals 2018-2019
by Ventucky Red. 07/19/18 12:47 PM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
F16 Effect Crew Weight Solo and 2 Up
by tback. 06/25/18 08:56 AM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
rivet guns #39383
10/23/04 11:30 PM
10/23/04 11:30 PM
JonandOliver Offline OP
I am replacing my rear track and bought a hand rivet gun, but the nose is too big to fit in the track to pull the rivet. Anybody know of a gun that can do the job on the rear track?
Re: rivet guns [Re: JonandOliver] #39384
10/24/04 07:35 AM
10/24/04 07:35 AM
You don't need to get a new gun - just stack a few small washers on the tail of the rivet - just enough to get clearance for the nose of the gun. Too many though, and there won't be enought "tail" for the gun to grab onto.
I've even used a small nut before. It's not perfect, but it works.
Since you're doing the whole track, I would consider modifying the nose of the gun to fit the track. I used a Dremel tool to cut away enough material so that the nose fits into the track.
Two tricks for installing the track:
- Use a large drill bit to slightly (and I mean slightly) increase the countersinks on the track. It's OK for the rivet heads to be below the bottom of the track. It's very bad for them to be above it - they'll catch the bottom of the traveller, which can hang up on one side when you least want it to hang up.
- Use duct tape to hold the track down and in place while you rivet it. The track has to be firmly seated on the crossbar and the rivet firmly seated in the hole. The rivet will not pull the track down if it's loose, and you end up with loose rivets.
Good luck! (I hope you bought a good gun - you've got a lot of rivets to pull!)
Re: rivet guns [Re: mbounds] #39385
10/24/04 08:06 PM
10/24/04 08:06 PM
Worked great! Thanks for the tips.
0 registered members (), 23 guests, and 299 spiders.
Beata, PiratesCoveCat, knussy, reiser5, Privilege
7808 Registered Users
Gato 3
JeffS 3
mmadge 1
Topics22,311
Posts266,603
Members7,808
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
