Photos of new mast bases and AHPC snuffer #44140
02/11/05 10:00 PM
02/11/05 10:00 PM
Arkansas, USA
C
CaptainKirt Offline OP
C
Arkansas, USA
Hopefully I will post some photos of the new AHPC stainless steel mast bases (both the A cat and Taipan 4.9) and the AHPC snuffer hoop and bag as well as a Taipan/A cat mainsail hook and the rubber "O" ring seals for the beam bolts-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of new mast bases and AHPC snuffer [Re: CaptainKirt] #44141
02/11/05 10:02 PM
02/11/05 10:02 PM
Arkansas, USA
C
C
Arkansas, USA
Here's another of the bases-
Kirt Simmons
Taipan, Flyer
Re: Photos of new mast bases and AHPC snuffer [Re: CaptainKirt] #44142
02/11/05 10:03 PM
02/11/05 10:03 PM
Arkansas, USA
C
C
Arkansas, USA
Here's last one of the new Taipan mast base-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of new mast bases and AHPC snuffer [Re: CaptainKirt] #44143
02/11/05 10:06 PM
02/11/05 10:06 PM
Arkansas, USA
C
C
Arkansas, USA
Here's one of the snuffer and bag- Snuffer hoop weighed 520 gms as I remember (without the bag)-
The bag has a bolt rope in the front that feeds into the slot in the hoop-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of new mast bases and AHPC snuffer [Re: CaptainKirt] #44144
02/11/05 10:07 PM
02/11/05 10:07 PM
Arkansas, USA
C
C
Arkansas, USA
Closer up shot of the snuffer-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of AHPC snuffer [Re: CaptainKirt] #44145
02/11/05 10:09 PM
02/11/05 10:09 PM
Arkansas, USA
C
C
Arkansas, USA
Here's the rear of the bag-
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of mast hook and beam bolt "O" rings- [Re: CaptainKirt] #44146
02/11/05 10:13 PM
02/11/05 10:13 PM
Arkansas, USA
C
C
Arkansas, USA
Here's one of the mast hook ring, beam bolt "O" rings (to seal the beam bolt holes), and the dense foam "block" that goes under the shackle portion of the hook ring to hold the ring upright so it will catch on the hook at the top of the mast. Note the ruler in ENGLISH (inch) measurements just to annoy Wouter!
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of new mast bases and AHPC snuffer [Re: CaptainKirt] #44147
02/12/05 04:00 AM
02/12/05 04:00 AM
Netherlands
Marc Woudenberg Offline
Netherlands
And this is it when fitted.
44526-Ned302 109.jpg (163 downloads)
Marc Woudenberg
T49/F16 Ned302
Weight of the whole snuffer [Re: CaptainKirt] #44148
02/12/05 06:10 PM
02/12/05 06:10 PM
I weighted the ring, bag, bungees, clips and rivets together and I seem to remember the total weight was 1.2 kg = 2.64 lbs
The haeavy duty Hobie tiger (yellow) trampoline bag I brought to springfever 2002 weigths 1.1 kg
The lightweight trampoline bag I had for my P18 + spi weighted in at 0.45 kg = 1 lbs
So I think this AHPC snuffer is a very good deal considering its overall weight. Its price is alot better than the competition as well. It works well, better than most laminate ring and sock systems I have used on other boats.
I'm quite happy with this AHPC snuffer. And I wouldn't trade it for another.
P.S. I have a normal cloth spi and never siliconed, lubed or greases it. It still goes in more easily than the other systems I've tried.
What is that ... [Re: CaptainKirt] #44149
02/12/05 06:14 PM
02/12/05 06:14 PM
What is that arm (lever) on the upper mastfoot. Mast spanner ?
And here you see it fitted to my boat ! [Re: Wouter] #44150
02/12/05 06:23 PM
02/12/05 06:23 PM
Only I had the white cloth bag instead of the grey one. I like the grey colour better. I never realized that there was a choice.
Don't mind the different lines that is all much tidier now
44545-KODAK 209_40%.JPG (40 downloads)
post holding pic (NM) [Re: Wouter] #44151
02/12/05 06:26 PM
02/12/05 06:26 PM
Re: And here you see it fitted to my boat ! [Re: Wouter] #44152
02/12/05 11:40 PM
02/12/05 11:40 PM
Arkansas, USA
C
C
Arkansas, USA
Wouter-
I didn't know there was a choice either- I just ordered one and that's what I got! What is the diameter, wall thickness and length of your "strut" to the spi pole?
Also, do you know where the front most small line from the snuffer ring is supposed to go?? I noticed you just have your's tied around the pole!
Kirt
Kirt Simmons
Taipan, Flyer
Re: It is the "new style" Flyer rotator arm [Re: Wouter] #44153
02/12/05 11:46 PM
02/12/05 11:46 PM
Arkansas, USA
C
C
Arkansas, USA
Wouter-
The strut projecting out the rear of the uppermost mast base (the Flyer base) is the rotation limiter arm- The "stock" Flyer setup has a grommet in the middle of the tramp through which the rotation limiter line projects and then it runs through a small block shackled to the rear of the this arm. My original setup had twin small SS tubes bolted to the aluminum mast base and projecting rearward. These are notorious for breaking at the mast base since they have very little vertical support so they get flexed vertically and end up breaking.
These bases look quite nice but I'm interested to see how much heavier they are than my current aluminum bases. Not an issue on my Flyer since it's got ~10 lbs. of lead in it now to get to legal weight!
Kirt
Kirt Simmons
Taipan, Flyer
A few answers [Re: CaptainKirt] #44154
02/13/05 12:18 AM
02/13/05 12:18 AM
I will have to get back to you on that. Give me a little time.
yeah that picture was taken right after the DCC and we had to quick fix a few things.
Actually in a few special cases the spi cloth was reported to catch in the V between the pole and ring. I have never encountered this problem, but I always fully tension the retrieval line before uncleating the halyard. My spi is as good as tube before it enters the mouth and I don't think it can hang that way.
But the line is a remedie for the spi hanging up like that. You rivet a small saddle under you pole at about a foot ahead of the ring and you tie that line of to that. Now you have a little triangle between the line the pole and ring. Therefor the line prevents the spi from going into the V between the ring and pole. That is is.
But at the DCC the tying off the line to the pole as showed didn't cause any problems.
Re: And here you see it fitted to my boat too! [Re: CaptainKirt] #44155
02/13/05 03:46 AM
02/13/05 03:46 AM
Netherlands
Netherlands
Kirt,
Since Wouter needs time to look things up, may I help you out on this one?
Spi pole diameter(ouside)is 40 mm. Spi pole length as supplied by AHPC to me is 3.300 mm.
Strut length between bridle plate and spi pole may vary according to luff length of your spi. I made a prototype one that is a one piece units from 16 x 1 mm stainless steel tube. See attached picture. To make it clearer a detailed drawing is available too, showing the dimensions in mm.
There are 2 small lines from snuffer ring. One is supposed to go to the bridle attachement on the closest hull, the other should go forward in an approx 45 degrees angle to the spi pole eyelet riveted onto the spi pole forward of the snuffer ring. On Wouters picture you noticed the spi pole is blank, so he had to tie it to the closest item. This line should prevent the spi from getting stuck between the ring and pole.
44570-Ned302 003.jpg (111 downloads)
Marc Woudenberg
T49/F16 Ned302
Re: Thanks Marc! [Re: Marc Woudenberg] #44156
02/13/05 11:36 PM
02/13/05 11:36 PM
Arkansas, USA
C
C
Arkansas, USA
Marc-
Thanks for the photo and the info.
Kirt
Kirt Simmons
Taipan, Flyer
Re: Photos of mast hook and beam bolt "O" rings- [Re: CaptainKirt] #44157
02/14/05 01:13 PM
02/14/05 01:13 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
I don't recall any O rings when I assembled my boat--should I add them?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Beam bolt "O" rings- [Re: ejpoulsen] #44158
02/14/05 04:45 PM
02/14/05 04:45 PM
Netherlands
Netherlands
Eric,
The "O" rings would have been in a recession under the beam bed, not protruding from the surface.
When I got mine, they were barely visible, but present.
Marc Woudenberg
T49/F16 Ned302
Re: Beam bolt "O" rings- [Re: Marc Woudenberg] #44159
02/14/05 06:32 PM
02/14/05 06:32 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
I still don't recall any--maybe I should unbolt and check. What is the torque value when retightening?
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
0 registered members (), 511 guests, and 84 spiders.
Posts267,056
