| Re: Rick's New Taipan F16 Rudder Design
[Re: Wouter]
#48744 01/24/06 09:05 PM 01/24/06 09:05 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I had a Dotan system on my M 6.0. If you sail in an area where you can put them down and not worry about ever having to sail with them in the kicked up position I'd rate them a 4 on a scale to 10.
Some of the problems. When kicked and trying to steer they flex a lot. The rudder blades float so when they kick they raise so high as to make it impossible to steer. You don't want to be around me when that happens. ( I understand why they float) If you snug up the pivot screw you can stop this from happening but then they become difficult to operate. The screws that are part of the pivot mechanism bent. I also broke a rake adjusting screw when hitting the bottom. A lot of small parts.
my 0.02
[Re: Dotan]
#48746 01/29/06 09:08 PM 01/29/06 09:08 PM |
Posts: 9,582 North-West Europe | Could you please tell who made a test on G-cat F16? Where is it possible to get more information about it?
Brett Moss and Hans Geissler I think you can contact Hans via his website : http://www.g-catmultihulls.com/Wouter
[Re: Wouter]
#48747 02/01/06 09:04 AM 02/01/06 09:04 AM |
Posts: 17 | Wouter: This is an interesting thing to know... Last time I heard about Hans Geissler he was going to race equipped with Dotan rudders. Second thing is that Dotan rudder boxes have been used on G-Cat 21' during some time. So far there haven't been any problems reported about weak rudder boxes from the owner. Something makes me believe that rudder loads on G-cat 21 are higher than on G-cat 16. I shall definitely try to get an update from them. | | | Re: Rick's New Taipan F16 Rudder Design
[Re: Dotan]
#48748 02/01/06 04:14 PM 02/01/06 04:14 PM |
Posts: 9,582 North-West Europe | Friend, Last time I heard about Hans Geissler he was going to race equipped with Dotan rudders.
Yes, they raced them on the new G-cat F16 and it was reported that they broke and proved to be not stiff enough. Now we can talk around these rudders for ever but the that doesn't change what happened. I don't care much about what works on the G-cat 21. I think most of us are only interested in what works on F16's. Now I'm not saying that the rudders are at fault here. I'm just relaying what reached my ears. Don't shoot the messenger, take this offline with Hans and Brett. Wouter
[Re: Dotan]
#48749 02/01/06 04:30 PM 02/01/06 04:30 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Dotan, In the picture you included in your post, which appears to be the aft end of a G-cat, the rudder looks to be tilted off center (gudgeons not aligned properly?). And, in addition to that, the the rudder blade itself appears to be twisted a bit from top to bottom.
[Re: Mary]
#48750 02/04/06 07:57 AM 02/04/06 07:57 AM |
Posts: 17 | Wouter: There are 1000 and 1 reasons why the rudders break - negligence, skipper errors, improper "center of the lateral plane", defects in workmanship, weakness of the materials etc. If the problem is on our side, we would like to address this problem and solve it. Consequently.. in order to find out where the problem is, we have to get feedback from every sailor with such experience and analyze all the facts.
Mary: You are right, as you can see in the photo, the rudder is tilted off-centre. However, there is not a problem with this and the gudgeons are aligned properly. This setup(when gudgeons are not centered) gives a small, positive effect when taking into consideration sailing at heel. In this case it is very important to preserve rudder parallelism.
Without any doubt, the rudder blade is not twisted. It looks like an optical distortion or something like this. | | | Re: Rick's New Taipan F16 Rudder Design
[Re: Dotan]
#48752 02/04/06 09:59 AM 02/04/06 09:59 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | the rudder is tilted off-centre. However, there is not a problem with this and the gudgeons are aligned properly. This setup(when gudgeons are not centered) gives a small, positive effect when taking into consideration sailing at heel. In this case it is very important to preserve rudder parallelism. Dotan, Can you explain what you mean by "rudder parallelism"? | | | Re: Rick's New Taipan F16 Rudder Design
[Re: Dotan]
#48754 01/15/07 08:26 PM 01/15/07 08:26 PM |
Posts: 1 | Possibly rudder parallelism is not a good word. When you cross the rudder blades in horizontal plane, rudder blade section chords(red lines on the photo) should be parallel between themselves. I beleive that the ABA AMRO boats found that 2 degrees toe in on their rudders gave the best results, would this be the small for cats. | | | Re: Knock it off !
[Re: Wouter]
#48755 01/17/07 10:19 AM 01/17/07 10:19 AM |
Posts: 390 |
Knock it off guys !
The deal was very clear. We will not give a certain person cause to post on this forum and this person will not post on the forum ever again.
Observe the conditions of the truce, please.
Anything and Everything can be discussed on this forum with the exception of S.E. or any statements that were made regarding this person in the past.
Wouter, You arrogant pompous, lying scumbag. I don't have a "deal" with anyone, certainly not YOU. There is no "truce", or agreement or understanding. I chose not to post because I was bored. I will post on any forum I want to. I will post about anything I want to. Who do you think you are? As we repeatly told you when Rick White first created this forum, YOU ARE NOT IS CHARGE. This is not YOUR forum. The people who choose to post here ARE NOT UNDER YOUR CONTROL. Perhaps it is time I resumed posting. The newbies should know the true history of you and the f16 "class". Like how you stole a set of Taipan 4.9 plans, had a pair of hulls made with a few minor above the waterline changes and called it "YOUR" design. You called it a tiafoon and never did pay the license fee to the real designer. BRING IT ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! | | | Re: Knock it off !
[Re: Robi]
#48758 01/17/07 06:18 PM 01/17/07 06:18 PM |
Posts: 915 Dublin, Ireland | abuahuauhauhahuabuuauahahahahahah look whos back! LMAO! some one sponsor the popcorn! LOL Maybe someone has found a way to post, using an existing forum members ID <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Dermot Catapult 265
| | | Re: Knock it off !
[Re: samevans]
#48759 01/17/07 10:51 PM 01/17/07 10:51 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Sam, At Wouter's behest, I contacted AHPC about your charges, and Greg Goodall replied to me as follows: I can confirm that Wouter did buy the plans #243 for a Taipan 4.9 catamaran. Wouter’s statement regarding this is 100% accurate.
The boat that Wouter built was a variation of the Taipan 4.9 and when completed it did not fit within the Taipan 4.9 class rules. It was never intended to be a class legal Taipan 4.9 as the intention was to be a F16 catamaran. For this reason the boat was called a Typhoon. I hope this sets the record straight. | | | Re: Knock it off !
[Re: bobcat]
#48760 01/17/07 10:59 PM 01/17/07 10:59 PM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | OK I can take neither blame nor credit for this. As to posting, I've been working on my monohull all year, Computer fritzy half the time. Looking forward to seeing you guys at Spring Fever's 10th Anniversary this spring. CARY C&C 24 "Caliente" SEACATS Damn, its alive. And just because of something Zuhl posted. He hasn't posted here since Feb 13th, 2006. (Zuhl that is). | | | Re: Knock it off !
[Re: Mary]
#48761 01/17/07 11:06 PM 01/17/07 11:06 PM |
Posts: 2,718 St Petersburg FL | Sam, At Wouter's behest, I contacted AHPC about your charges, and Greg Goodall replied to me as follows: I can confirm that Wouter did buy the plans #243 for a Taipan 4.9 catamaran. Wouter’s statement regarding this is 100% accurate.
The boat that Wouter built was a variation of the Taipan 4.9 and when completed it did not fit within the Taipan 4.9 class rules. It was never intended to be a class legal Taipan 4.9 as the intention was to be a F16 catamaran. For this reason the boat was called a Typhoon. I hope this sets the record straight. OOOOOOOOOOOH!! so who is the liar now? <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> I am sure Sam wont reply he has selective reading. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Ill be waiting for the nasty private message Sam. You know how I do it, I am your crying shoulder <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> ps: I love this forum. Nothing like reading good ol fashion Hobie bashing, Nacra greatness, fad boats and how the polynesians found land by reading wave intervals <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Knock it off !
[Re: Robi]
#48763 01/18/07 06:23 AM 01/18/07 06:23 AM |
Posts: 3,348 | Sam, At Wouter's behest, I contacted AHPC about your charges, and Greg Goodall replied to me as follows: I can confirm that Wouter did buy the plans #243 for a Taipan 4.9 catamaran. Wouter’s statement regarding this is 100% accurate.
The boat that Wouter built was a variation of the Taipan 4.9 and when completed it did not fit within the Taipan 4.9 class rules. It was never intended to be a class legal Taipan 4.9 as the intention was to be a F16 catamaran. For this reason the boat was called a Typhoon. I hope this sets the record straight. OOOOOOOOOOOH!! so who is the liar now? <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> I am sure Sam wont reply he has selective reading. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Ill be waiting for the nasty private message Sam. You know how I do it, I am your crying shoulder <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> ps: I love this forum. Nothing like reading good ol fashion Hobie bashing, Nacra greatness, fad boats and how the polynesians found land by reading wave intervals <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> | | |
625
guests, and 166
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
