buoyancy #52173
06/30/05 02:42 PM
06/30/05 02:42 PM
bolivar Offline OP
bolivar  Offline OP
Which of the more or less standard solocats (HC17, HC FX one, Nacra I17) or cats that can be easily managed with unirig (5.5SL, F16?..) has the most buoyancy (regardless where it is located)?
Bart
Re: buoyancy [Re: bolivar] #52174
06/30/05 03:43 PM
06/30/05 03:43 PM
Why are you asking ?
Re: buoyancy [Re: bolivar] #52175
06/30/05 04:02 PM
06/30/05 04:02 PM
samevans Offline
samevans  Offline
Do you mean the maximum hull displacement (the total volume of the hulls x weight of water)?
Or the maximum crew weight before performance suffers too much?
Some boats tolerate additional weight better than others.
There is also the A Class, the 18 Square Meter Class, the Nacra 450 & 500, and the Mystere 4.3.
The Nacra 5.5 was also built as a Unirig.
Re: buoyancy [Re: bolivar] #52176
06/30/05 08:19 PM
06/30/05 08:19 PM
The nacra 5.5 has tons of volume in the hulls compared to the rest on your list.
Re: buoyancy [Re: bolivar] #52177
07/05/05 04:59 PM
07/05/05 04:59 PM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
Of the three you listed, the I-17 has the best hull volume. I have seen it sailed with two good sized adults and do quite well.
Les Gallagher
0 registered members (), 576 guests, and 42 spiders.
