| Re: Gelcoat
[Re: MattUF]
#52685 07/11/05 03:38 AM 07/11/05 03:38 AM |
Joined: Mar 2005 Posts: 66 Durban, KwaZulu-Natal, South A... Clint_SA
Posts: 66 Durban, KwaZulu-Natal, South A... | Hi Matt. With regards to checking whether to gelcoat or fibre glass. A boat hit me this weekend, and the bolt at the front of the bows (for the bridle cables) scratched off the gelcoat on my upper deck. Took the gelcoat off in a 3 inch scratch. I was just thinking of replacing the gelcoat. Should I also do the bubble test Matt?
Dubulamanzi
| | | Re: Gelcoat
[Re: Clint_SA]
#52686 07/11/05 08:05 AM 07/11/05 08:05 AM |
Joined: Jun 2005 Posts: 22 Gainesville, Florida MattUF
Posts: 22 Gainesville, Florida | It never hurts to do a pressure test on the area. Can you see strands of glass fibers sticking out around the damaged area? Is the area caved in? If the answer to both of these questions is "no", then I would just clean it up with some 150-200 grit sand paper, wipe the area down with acetone, and patch the gelcoat. If your boat hull is white, you could use marine tex to fill the scratch. After it hardens, it can be sanded very smooth and looks o.k. Later, when you have more scratches to fill, you can buy a gelcoat patch kit and do them all at the same time. If you have a digital camera, you could post some close-up pics, which would make it easier to determine the best course of action. Good luck! -Matt | | | Re: Gelcoat
[Re: aaronhoy]
#52689 07/11/05 08:16 PM 07/11/05 08:16 PM |
Posts: 22 Gainesville, Florida | My hobie 16 is starting to come apart a little at the joint between the hull and deck, too. I think that in the fall I am going to try to fix it in this manner: first, flip it over and dremel a notch in the joint... V shaped, if possible maybe an eighth or a quarter inch deep (or until the fiberglass-resin matrix looks solid). Then, lay a thin coat of polyester or vinylester resin in it. As that begins to set, cut a sheet of fiberglass so that the strands are about a quarter inch long and mix them into enough resin to fill the notch with the resin-fiberglass mash. Next, pack it in really well with a popsicle stick and toothpicks to get out the air bubbles. Finally, tape off both sides so that the tape extends about half an inch above the sides of the joint and pour resin over the repair all the way around (just slightly above the ridge). After it sets, sand it down to a nice rounded lip. If anybody has tried this before and run into problems, please let me know. Thanks! | | |
234
guests, and 45
