| Re: Blade in waves
[Re: rbj]
#53563 07/21/05 06:22 PM 07/21/05 06:22 PM |
Posts: 548 MERRITTISLAND, FL | Jerry,
It depends heavily on your definition of waves or chop, and how much wind there is. Here is a rough shot of my experience, Phill may want to add some more.
The Blade has a very full almost flat bottom, so in conditions where you are dropping off the back side of 6' footers, or sailing in the bay with 2' short chop and boat wake with light air, it does make a lot more noise slapping the water than a V-hull. These are the 2 conditions that I have actually noticed hull slap. Chop under 1 foot clears the hulls fine. In the bigger chop, as soon as you have a little more wind (enough for both people to sit windward when 2 up) the boat drives right through it.
Everything is a trade off when talking design. The additional slap present when it is choppy and light, IMO is far out weighed by the the benefit that the volume distribution provides in minimizing pitching. When you can keep the boat from pitching in waves you can sail a lot faster.
M | | | Re: Blade in waves
[Re: Matt M]
#53564 07/21/05 08:37 PM 07/21/05 08:37 PM |
Posts: 9,582 North-West Europe | While the Taipan 4.9 cut really nice is most conditions it can get pretty bouncy as well.
Just last weekend. We did a comparison between a new FX-one and my Taipan F16, in sever short with a wavelength of just about one boatlength.
The FX-one looked rather stable in these conditions, I felt like I was on a bronco. It was just absolutely the wrong frequency for my Taipan. The wind dropped so I could really use the sail to stabilize the boat. Finally I moved around a little bit and found a spot that was sort of acceptable. Boat was still going up and down but not coming to a full stop every 20 seconds.
Still showed to be on the good side of the FX-one though. Saved my honour there, but it must be said, its hull shape took the conditions better despite being noisy. My point being that there will be a set of conditions where a cutter won't really do its thing when a wave-piercer will.
2 weeks ago I encountered conditions that really did favour a cutter. Each time when coming of the short waves the hulls would sink in and act like a suspension system keeping the rig moving about slowly through the air and not shake the attached flow off. It was just a beautiful delayed reaction the oncoming waves.
But I too think that the trade-off is in the favour of the newer hull shapes like the one used by the Blade.
| | | hell, ....
[Re: Robi]
#53570 07/24/05 05:49 PM 07/24/05 05:49 PM |
Posts: 9,582 North-West Europe |  hell, Jerry (RBJ) can go to several places in the world now and get a test ride on a Blade. Take your pick ! Wouter
318
guests, and 55
