| Re: Changi Sailing Club, Singapore
[Re: David Parker]
#55251 08/22/05 03:55 AM 08/22/05 03:55 AM |
Posts: 2 | That is indeed Changi Sailing Club. Have a look at www.csc.org.sg for more info and better photos (and some video footage too...) | | | Re: Changi Sailing Club, Singapore
[Re: David Parker]
#55252 08/22/05 06:28 AM 08/22/05 06:28 AM |
Joined: Jul 2005 Posts: 28 Peninsular Malaysia SkunkWORX OP
Posts: 28 Peninsular Malaysia | CSC is not a bad place to sail. In the NE Monsoon season (December - March) wind peaks at about 24knots but because Singapore is protected on all sides by Malaysia and Indonesia - we have flat water! Water temp is 24 degrees year-round and the beer is 10 degrees! If you visit http://www.csc.org.sg/water/race.htm over the next day or so, you'll see photos/video clips of the weekends race when the plywood cats took line honours. | | | who were the dogs?
[Re: SkunkWORX]
#55257 08/23/05 06:40 AM 08/23/05 06:40 AM |
Posts: 185 Shanghai, China | seemed to have been a more rainy than windy event? looking at the results your race times seemed to be very short between 15 - 30 minutes...? and looking at the videos it seemed you run starboard mark courses?
just curious,
dirk
Dirk
A-Cat GER 5
F-16 CHN 1 (sold)
SC 6.5 CHN 808
[Re: Clay]
#55259 08/23/05 11:09 AM 08/23/05 11:09 AM |
I would make all the preparation for such a raising system when building the hulls. Then as you say it can easily be added later.
I race most doublehanded and I find that I nearly always keep my boards down. It seems that with the Taipan boards you can get away with that; all the way up to where the winds gets really honking. I for now am making the trade-off that leaving them down speeds up our transitions and keeps the decks clear while the negative effects are pretty minor. Not to mention that hitting a board with your elbow or something is a real pain. I think the negative effect is that the boat is a little bit more nervous on the downwind but that doesn't seem to bother us much (my crew and I). We compensate for it with other skills.
I do solo sailing quite often recreationally and here the system would be a nice to have, but the final eyes haven't made it too my boat yet even though I have them laying around. Probably next year.
[Re: Clay]
#55261 08/24/05 06:05 AM 08/24/05 06:05 AM |
Posts: 28 Peninsular Malaysia | No conspiracy, really. Just liked the whole Skunk Works concept that build all that top secret military aircraft!
As for the daggerboard system. No will leave it plain-Jane 1. one less string across the deck 2. we leave the boards fully down al the time, except for beaching!
Leaving the boards down gives the boat more bite. The hull will fly earlier and you shake of the drag quicker so your boat speed goes up. Especially downwind, with the boards down I find you can control the whole match so much easier. THe modern F-16 has so many other controls to make your hi-speed life easier that the boards can almost be forgotten.
With the string system, if your moving along quickly there will be side load on the boards and you can't pull then up with the string anyway. Better not to have the string then!? Put it in by all means and try it out, If you don't like it, just take it off.
When you finally get around to sailing your Blade you will want to do anything to make the hull fly earlier. When that hull comes up the dynamics really take over and she will really climb to windward at a great rate of knots.
We just got the opportunity to 'test' Agent Orange against some of our Taipans. In light no hull flying winds, speed and angles are a match. As the Taipan crews slowly edge out to the wire, they hold a slight advantage. The Blade is full width F-16 in comparison so hull lift-off will be a bit later. But there is a big benefit to 'sitting in' longer on the Blade. Once the hull lifts the bow section really comes into play and the speed jumps up as the boat climbs to windward. It is as if the boat ahead just bears away! It was pretty amazing to see it happen even though it sounded like a story to me!
Thailand's not far away about an hour in a jet. If he's sailing, there are a couple of places with some good set ups and nice water.
cheers | | |
677
guests, and 36
